can't be online plzzzzzzz help
rrgrrg
Well, none.com only comes up if Atari detects a pirate serial. If you are telling the truth that you actually bought the game, then its a problem with your game and you need to contact Atari.
Did you download a pirate megaack?? The same thing happens if you have that installed and it isn't a legit copy. If that is the case, completely remove TDU (including Documents and settings/Application data/Test Drive Unlimited) and install the game again.DO NOT reinstall the megapack if it is a pirate. Just delete it and pay the $10US for it. But if the actual TDU game is a pirate, you will not be able to play online and it is illegal so I strongly recommend paying the small amount of money to buy the game.
Hope that helps
