What order have you done it in, i had this problem because i installed it wrong.
1.install game
2.install megapack if you have it
3.install patch
4.install Djey's magic map
5. add mods
If this dosent work im not sure what will, hope this helps.
The right way
1 - Install TDU
2 - Install patch 1.66A
3 - Install megapack
4- Install 1.67d or 1.68b
Enjoy
If you have a error message while instaling, copy paste here "patch.log" and "ModAndPlayDebug.log"
Thanks
i have the same problem, any solutions for this?
patch.log:
Log C:\Users\Wiktor\Desktop\TDU_PATCH_1.68B\Patch 1.68b\patch.log
Enabled : True
Events : 7
Has new event : True
> 2011-01-03 22:27:37 - Running patch C:\Users\Wiktor\Desktop\TDU_PATCH_1.68B\Patch 1.68b\patchs\install.pch - 94 instruction(s).
> 2011-01-03 22:27:37 - Chosen install groups: [Required;Generate New Traffic;1.68].
> 2011-01-03 22:27:37 - Running instruction #1 from group 'Required': Brands_name_700...
> 2011-01-03 22:27:37 - Exception spotted: Unable to create edit task on BNK file: J:\Test Drive Unlimited\\Euro\Bnk\Database\DB_FR.BNK
> 2011-01-03 22:27:37 - Instruction #1 ended with error.
> 2011-01-03 22:27:37 - Patch halted because of an error.
> 2011-01-03 22:27:37 - No collected messages.
ModAndPlayDebug.log
** 2011-01-03 22:30:53 ERROR
*** Exception > Unable to create edit task on BNK file: J:\Test Drive Unlimited\\Euro\Bnk\Database\DB_FR.BNK
w TDUModdingLibrary.support.patcher.instructions.UpdateResourceI._Process()
w TDUModdingLibrary.support.patcher.instructions.PatchInstruction.Run(Log currentLogger)
-- parent exception --
*** ArgumentOutOfRangeException > Indeks jest spoza zakresu. Musi mieć wartość nieujemną i mniejszą niż rozmiar kolekcji.
Nazwa parametru: index
w System.ThrowHelper.ThrowArgumentOutOfRangeException(ExceptionArgument argument, ExceptionResource resource)
w System.ThrowHelper.ThrowArgumentOutOfRangeException()
w System.Collections.Generic.List`1.get_Item(Int32 index)
w System.Collections.ObjectModel.Collection`1.get_Item(Int32 index)
** 2011-01-03 22:30:53 ERROR Error when running core patch instructions.:System.Exception: Patch was not applied as a critical error occured.
Please contact author of this mod then Modding Tools support, eventually.
(Patch was not applied as an error occured.
Please refer to the log files for more information.) ---> System.Exception: Patch was not applied as an error occured.
w TDUModdingLibrary.installer.steps.PatchTask.Run()
--- Koniec śladu stosu wyjątków wewnętrznych ---
w TDUModdingLibrary.installer.InstallHelper.RunAll(PCH patch, Log log, Culture culture, Boolean isInstall, List`1 chosenInstallGroups)
*** Exception > Current patch can't be installed:
w TDUModAndPlay.gui.MainForm._Process(Boolean isInstall)
*** Exception > Patch was not applied as a critical error occured.
*** Exception > Patch was not applied as an error occured.
** 2011-01-03 22:30:55 INFO Unable to remove temporary folder - does not matter.
