Sign in to follow this
FerrariDriver12
Ducati Desmocedici Sound Mod by Helper123
You see your gameversion when you start the uplauncher. Problem is the uplauncher will start to update the game again. Sorry but with original gamefiles i can't help you out. It's against boardrules. And i still think that it doesn't have something to do with the carmodelfiles if you didn't change anything in the high-, interiors-, med- or rimfolder.
How are you running the unpacked version? Do you have a separate copy of the game which you unpacked or did you unpack the originally installed gamefolder? If you have a separate copy (like i did) then let the uplauncher check the packed folder, copy the original testdrive2.exe into the unpacked folder and test it again.
Share this post
Link to post
