Wildcat
where and how to edit ground textures
First unpack the ''commonworld.bnk'' to access the textures
Ground textures are in this folder, use Texture Viewver for export DDS texture
commonworld.bnk\5Prepared\PC\EURO\Level\Hawai\Common\maps\detail
69053253_2365313610398733_59073846913584
68845648_2365313587065402_63117474699107
With texture viewer exports texture in DDS format. Edit what you want and then save it in the appropriate format (DDS) DTX1 or DTX5
67757656_2365313717065389_32990896986133
It is important to make a copy of the folder that you are going to modify to be able to cover the texture well, if not only it will look yellowish, then convert it to 2DB with the Texture Converter, with the following steps
68422764_2365313637065397_11793229949928
68372453_2365313740398720_89509902747088
68238330_2365313750398719_86086103166888
And so that the textures look good you can create the normalmap with this page (with tis configuration the normalmap looks good, then edit the PNG texture to DDS to be able to convert it to 2DB)
68599847_2365313813732046_40262457908831
http://cpetry.github.io/NormalMap-Online/
I hope you have understood and it has been helpful.
Share this post
Link to post
