Johny01
  • 3 years later...
On 6/11/2023 at 9:58 PM, AWStudio said:
!?... You should check it because the GPS does not work, the driver's position is bad and the exterior turning lights are non-existent.
For the GPS try the flashlights 😉 In the past i tried some car from Irinka, may be some merc c class coupe and noticed that the GPS was connected to the headlights and was working at night when headlights was on, at the day was able to see GPS only when i hit the flashlight. Thats not good and if its the only way to work must make headlights to work nonstop, day and night...
The drivers position is in your "camerasingame" file (not in the car mod) and you can fix it with TDU2CVE tool.
Dont know about turning lights, i didnt try this car, this brand is not my favorite...
Edited by SilverBENZ
