You can't do Heel & Toe shifting in TDU, seeking solution
vanobmw33
Hello Everyone,
Today I found out that you can't do Heel & Toe shifting in TDU. Judging by that TDU uses "Report Combined Pedals" in order for pedals to work correctly, when you try to Heel & Toe two pedals are being pressed at the same time and "Report Combined Pedals" mapped inputs cannot handle it.
As a result we get neither brake or throttle when doing it. Basically all this means that it's impossible to Heel & Toe in TDU, the only thing you can do is Rev Matching on straights without brakes involved.
Is this something that can be fixed? Have anyone looked into this issue or are there any mods for it? Wonder if anyone have noticed this using Logitech wheels
Edited by vanobmw33
Added photo
This will be because you enabled 'Report Combined Pedals' to solve another problem in your other thread.
When the pedals are combined, they share one axis.  It is therefore impossible to accelerate and brake, just like it is impossible to steer left and right at the same time.
Im aware of the issue this method causes with Axis, but what else is there to do? Without this method pedals don't work properly. Also came across more than one source which suggest to turn on "Report Combined Pedals" for pedals to work properly in TDU.
This is confusing. Shared axis pedals won't do Heel & Toe back in 2010 either. Does this mean nobody cared about it?
