TDUPE Problem
Thozan
hi all!
i've got this problem with TDUPE..
I want to make an W12 VW Golf, but every time i try to save the car (First save changes, then crtl+s) is says(in half Dutch/English) :
************** Tekst van uitzondering **************
System.Exception: Error when encrypting file: C:\Documents and Settings\Eigenaar\Bureaublad\gamez\Test Drive Unlimited editor\temp\output.hex ---> System.IO.FileNotFoundException: Kan bestand C:\Documents and Settings\Eigenaar\Bureaublad\gamez\Test Drive Unlimited editor\temp\output.hex niet vinden.
Bestandsnaam: C:\Documents and Settings\Eigenaar\Bureaublad\gamez\Test Drive Unlimited editor\temp\output.hex
bij System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
bij System.IO.FileInfo.get_Length()
bij TDUModdingLibrary.support.encryption.XTEAEncryption.Encrypt(String iname, String oname)
--- Einde van intern uitzonderingsstackpad ---
It seems that TDUPE can't find output.hex?? when i start TDUPE and i look into the Temp map, there it is! But when i save a car (doesn't matter wich one) output.hex dissappears???
Anyone please help?
Greetz
hey man not working for me i cant load cars the drop down box is empty and i always get this message
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at TDUeditor.Form1.loadCarButton_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at ComponentFactory.Krypton.Toolkit.KryptonButton.OnClick(EventArgs e)
at ComponentFactory.Krypton.Toolkit.KryptonButton.b(Object A_0, MouseEventArgs A_1)
at ComponentFactory.Krypton.Toolkit.ButtonController.OnClick(MouseEventArgs e)
at ComponentFactory.Krypton.Toolkit.ButtonController.MouseUp(Control c, Point pt, MouseButtons button)
at ComponentFactory.Krypton.Toolkit.ViewBase.MouseUp(Point pt, MouseButtons button)
at ComponentFactory.Krypton.Toolkit.ViewManager.MouseUp(MouseEventArgs e, Point rawPt)
at ComponentFactory.Krypton.Toolkit.VisualControlBase.OnMouseUp(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at ComponentFactory.Krypton.Toolkit.VisualControlBase.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.1434 (REDBITS.050727-1400)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
TDUeditor
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Users/Lily/Desktop/tdupe/TDUeditor.exe
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Assembly Version: 4.1.1.0
Win32 Version: 4.1.1.0
CodeBase: file:///C:/Users/Lily/Desktop/tdupe/ComponentFactory.Krypton.Toolkit.DLL
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Data
CodeBase: file:///C:/Windows/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
System.Transactions
CodeBase: file:///C:/Windows/assembly/GAC_32/System.Transactions/2.0.0.0__b77a5c561934e089/System.Transactions.dll
System.EnterpriseServices
CodeBase: file:///C:/Windows/assembly/GAC_32/System.EnterpriseServices/2.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
i really need help. every time when i start tdupe its says "Database not found". before i have installed win7 on my pc tdupe starts with no problems. i wanna change it for the 64bit win7 version. ..but how can i do it ? i have change the install directory and other things but nothing helps. everytime database not found. i cant believe this ....i really can freak out. pls help me
just a tip
in your " TDUPE " directory , open " TDUEditor.exe.config " with notepad . the value line should look like this :
<value>*\</value>
* - TestDriveUnlimited's install directory .
ok thx for help. i have fix this problem but now i have an other problem. i have win7 64bit and everytime when i start TDU with tdupe there i coming a messeage in the game after a few seconds " disconnected from game because incorrect game data".
......WHY ?
i have google the problem and looking here in forum but i dont know what i have to do now.
this is my tdupe install dicetory from the progam : D:\Spiele\Atari\Test Drive Unlimited\
this is the configure:
<?xml version="1.0" encoding="utf-8" ?>
<configuration>
<configSections>
<sectionGroup name="userSettings" type="System.Configuration.UserSettingsGroup, System, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" >
<section name="TDUeditor.Properties.Settings" type="System.Configuration.ClientSettingsSection, System, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" allowExeDefinition="MachineToLocalUser" requirePermission="false" />
</sectionGroup>
</configSections>
<connectionStrings>
<add name="TDUeditor.Properties.Settings.carDataConnectionString"
connectionString="Provider=Microsoft.Jet.OLEDB.4.0;Data Source=|DataDirectory|\carData.mdb;Persist Security Info=True"
providerName="System.Data.OleDb" />
</connectionStrings>
<userSettings>
<TDUeditor.Properties.Settings>
<setting name="locality" serializeAs="String">
<value>US</value>
</setting>
<setting name="tdupath" serializeAs="String">
<value>D:\Spiele\Atari\Test Drive Unlimited\</value>
</setting>
<setting name="appearance" serializeAs="String">
<value>Office 2010 - Blue</value>
</setting>
</TDUeditor.Properties.Settings>
</userSettings>
</configuration>
im having a problem that is new as its didnt happen before...
I run tdupe as 'adminstrator' and import the performance packs I want to import, but after saving each car individually and saving all changes and starting up tdu, it crashes after the two title videos and a vista message comes up saying this program wasnt running properly or something .... any help please?? :D
  • 4 months later...
Hi There i have a little problem...
System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
at System.ThrowHelper.ThrowArgumentOutOfRangeException(ExceptionArgument argument, ExceptionResource resource)
at System.ThrowHelper.ThrowArgumentOutOfRangeException()
at System.Collections.Generic.List`1.get_Item(Int32 index)
at System.Collections.ObjectModel.Collection`1.get_Item(Int32 index)
at TDUeditor.Form1.extractDecode()
at TDUeditor.Form1.Form1_Load(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at ComponentFactory.Krypton.Toolkit.KryptonForm.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at ComponentFactory.Krypton.Toolkit.VisualForm.WndProc(Message& m)
mscorlib
Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
TDUeditor
CodeBase: file:///D:/Gry/TDU/TDUeditor.exe
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Assembly Version: 4.2.0.0
Win32 Version: 4.2.0.0
CodeBase: file:///D:/Gry/TDU/ComponentFactory.Krypton.Toolkit.DLL
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Data
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
DjeFramework1
Assembly Version: 1.0.3738.25971
Win32 Version: 1.0.3738.25971
CodeBase: file:///D:/Gry/TDU/DjeFramework1.DLL
TDUModdingLibrary
CodeBase: file:///D:/Gry/TDU/TDUModdingLibrary.DLL
System.Transactions
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Transactions/2.0.0.0__b77a5c561934e089/System.Transactions.dll
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.EnterpriseServices/2.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
enabled.
For example:
<configuration>
</configuration>
Could somebody help please ?? :( (if that helps i got gold version of TDU)
Try as already someone wrote...
1.Change keyboard and culture language to english
2.Download mod tool again
3.when u open mod tool go to file>settings>game path and save it!
(so like this C:\ or D:\ or on what ever partition u have it mine is like this D:\program files\Atari\Test Drive Unlimited\)
It would be best to go to desktop and open your Computer and than folow and read where u go and make sure it is SAME as in settings in mod tool! and it is \ not /
4.I dont know if that have anything whit anything but i downloaded NET framework 4 and i solved my problem whit errors...
5.Check if u have all files needed posted in older post,there is 3-4 so it won`t be to hard,i have no time to chek them again,sry.
  • 4 months later...
Everytime I start tdupe it says: Unhandled exception application. If you choose to continue, the application will ignore the error and try to continue the operation. If you choose to quit, the application will close immediately.
Index was outside the table.
At the end of this message contains information about how you can
to introduce JIT debugging instead of this dialog box.
Text ************** ************** exception
System.IndexOutOfRangeException: Index was outside the table.
in TDUeditor.Form1.loadCar (String carRef, pasteData Boolean, Int32 data)
in TDUeditor.Form1.Form1_Load (Object sender, EventArgs e)
in System.Windows.Forms.Form.OnLoad (EventArgs e)
in ComponentFactory.Krypton.Toolkit.KryptonForm.OnLoad (EventArgs e)
in System.Windows.Forms.Form.OnCreateControl ()
in System.Windows.Forms.Control.CreateControl (Boolean fIgnoreVisible)
in System.Windows.Forms.Control.CreateControl ()
in System.Windows.Forms.Control.WmShowWindow (Message & m)
in System.Windows.Forms.Control.WndProc (Message & m)
in System.Windows.Forms.ScrollableControl.WndProc (Message & m)
in System.Windows.Forms.ContainerControl.WndProc (Message & m)
in System.Windows.Forms.Form.WmShowWindow (Message & m)
in System.Windows.Forms.Form.WndProc (Message & m)
in ComponentFactory.Krypton.Toolkit.VisualForm.WndProc (Message & m)
in System.Windows.Forms.Control.ControlNativeWindow.OnMessage (Message & m)
in System.Windows.Forms.Control.ControlNativeWindow.WndProc (Message & m)
in System.Windows.Forms.NativeWindow.Callback (IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
************** ************** Loaded Configurations
mscorlib
Configuration version: 2.0.0.0
Win32 Version: 2.0.50727.4952 (win7RTMGDR.050727-4900)
Code base: file: / / / C: / Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
TDUeditor
Configuration version: 1.0.0.0
Code base: file: / / / C: / Users / name / Documents / TDUPE / TDUeditor.exe
Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
Code base: file: / / / C: / Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Code base: file: / / / C: / Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
Code base: file: / / / C: / Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Configuration version: 4.2.0.0
Code base: file: / / / C: / Users / name / Documents / TDUPE / ComponentFactory.Krypton.Toolkit.DLL
Code base: file: / / / C: / Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
Code base: file: / / / C: / Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.dat
Code base: file: / / / C: / Windows/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
System.Windows.Forms.resources
Code base: file: / / / C: / Windows/assembly/GAC_MSIL/System.Windows.Forms.resources/2.0.0.0_fi_b77a5c561934e089/System.Windows.Forms.resources.dll
mscorlib.resources
DjeFramework1
Assembly version: 1.0.3738.25971
Code base: file: / / / C: / Users/name/Documents/TDUPE/DjeFramework1.DLL
TDUModdingLibrary
Code base: file: / / / C: / Users / name / Documents / TDUPE / TDUModdingLibrary.DLL
System.Transactions
Code base: file: / / / C: / Windows/assembly/GAC_32/System.Transactions/2.0.0.0__b77a5c561934e089/System.Transactions.dll
Code base: file: / / / C: / Windows/assembly/GAC_32/System.EnterpriseServices/2.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
JIT debugging requires that the
application or machine configuration file (Machine.config)
is jitDebugging system.windows.forms configuration section.
Error correction must also be using the application
translation.
For example:
<configuration>
</ Configuration>
When JIT debugging is enabled, the uncaught exception
sent to the machine registered JIT debugger function
and are not discussed in this dialog box. PLEASE HELP ME! I have win7 64bit
  • 6 years later...
