Season Mod Auto installer by TheDuck38
TheDuck38
    No I did not remove the read only tags before install.
    I have 68.6 GB left on this HDD
    I clicked admin rights in the compatibility tab before install
    I have no errors on the 64-bit OS just the 32-bit (which this isnt installed on).
    I also never had the original setbrushs when I installed. Would that be the cause?
    I unstalled the mod, but the mini map still shows snow trees. I have the bloom mod installed as well if that helps.
    • Replies 57
    I don't understand, do you have 2 versions installed ? One on a 64b OS, and one on a 32b OS ? And you only get errors with the 32b version ?
    What do you call 'original setbrushs' ?
    Did you make a backup of the TDU folder before using my app ?
    The bloom mod should not interfere.
    I'll make a package of the original files and upload them. So that you can replace the correct ones.
    TD38
    :oNo just one version, An Nvidia bios update messed up my other OS thats y it has HDD errors.
    Nah only the car related files before the I installed the season mod.
    The setbrushes consist of the trees in TDU which the paradise mod uses.:p
    OK, the SetBush file is not the problem cause, as the app just replaces files whatever they are...
    Is your Bios update the possible reason why you had random files errors ?
    If yes, it would explain everything that's in the log file and I still don't really understand...
    Here's the restoration files archive :
    http://www.filefront.com/17132781/Restoration-TDU-Normal-mode.7z/
    Just expand the archive, and in the folder there is a readme file, saying where to put each file. Drag them manually at their correct place. Normally this should restore you game.
    Just tell me if the game's still corrupted.
    If you solve your file issue, you may want to give another try to my app (it's worth, if working... :)). Consider making a complete backup of your TDU folder before, just in case; then re-install everything (make sure to clear before any 'TDU Seaon' folder or 'Hawai winter' in "euro/bnk/level")...
    TD38
    Sorry, but I must write my reply.
    TheDuck38 is literally busting his a** in order to help you out, and you're making no sense or whatsoever with your posts MegaXlr. And somehow, I got a feeling that you're playing with his patience.
    TheDuck38 did an amazing job with this app, everything is straightforward, he even wrote easy to follow guide.
    What do you want more from him? To come to your house and install it instead of you? I'm affraid, it isn't possible, so stop dreaming. But here's what you can do... uninstall your game, take a deep breath, and start again... this time be sure to follow his guide... and I can assure you, everything will work just like it worked for hundred of people so far.
    Good night.
    Error?
    I've got Windows 7
    Constantly shows me an error when I try to install the mod.
    I reinstall game... But i have same error.
    Error: No previous installation could be found to upgrade. This installation is an apgrade for prior versions. One of these prior versions could not be found on your computer and so thus there is nothing to upgrade.
    please help me about this ...:confused:
    This was translated from Serbian into English.
    I've got Windows 7
    This is, I suppose, because you didn't install previously the Crazy Winter Edition Auto installer (1,2 Gb to download)... Check my signature, and it is the first link.
    The Season Mod app will install only if you already have the Crazy Winter Auto installer in you TDU folder.
    Check also the readme file in the Season mod files.
    TheDuck38
    • 1 year later...
    10-31-2011 19:19:08 ===> Launching Season Mod application <===
    10-31-2011 19:19:59 --- Tropical Paradise v2.2 mode install ---
    10-31-2011 19:19:59 *** Error : script file not correct : C:\Program Files (x86)\Atari\Test Drive Unlimited\TDU Season\Tropical Paradise v2.2\Light roads\Light roads.script ***
    10-31-2011 19:20:19 --- Tropical Paradise v2.2 mode install ---
    10-31-2011 19:20:19 *** Error : script file not correct : C:\Program Files (x86)\Atari\Test Drive Unlimited\TDU Season\Tropical Paradise v2.2\Light roads\Light roads.script ***
    10-31-2011 19:21:09 *** Error : Unknown active mode ***
    10-31-2011 19:21:09 *** Restoration not attempted ***
    10-31-2011 19:21:16 --- Tropical Paradise v2.2 mode install ---
    10-31-2011 19:21:16 *** Error : script file not correct : C:\Program Files (x86)\Atari\Test Drive Unlimited\TDU Season\Tropical Paradise v2.2\Light roads\Light roads.script ***
    10-31-2011 19:22:12 --- Tropical Paradise v2.2 mode install ---
    10-31-2011 19:22:12 *** Error : script file not correct : C:\Program Files (x86)\Atari\Test Drive Unlimited\TDU Season\Tropical Paradise v2.2\Light roads\Light roads.script ***
    10-31-2011 19:22:29 --- Tropical Paradise v2.2 mode install ---
    10-31-2011 19:22:29 *** Error : script file not correct : C:\Program Files (x86)\Atari\Test Drive Unlimited\TDU Season\Tropical Paradise v2.2\Dark roads\Dark roads.script ***
    10-31-2011 19:22:47 *** Error : Unknown active mode ***
    10-31-2011 19:22:47 *** Restoration not attempted ***
    10-31-2011 19:24:01 --- Tropical Paradise v2.2 mode install ---
    10-31-2011 19:24:01 *** Error : script file not correct : C:\Program Files (x86)\Atari\Test Drive Unlimited\TDU Season\Tropical Paradise v2.2\Light roads\Light roads.script ***
    10-31-2011 19:24:06 ===> Launching TDU <===
    10-31-2011 19:25:15 ===> Exiting Season Mod application <===
    10-31-2011 19:27:26 ===> Launching Season Mod application <===
    10-31-2011 19:27:56 --- Tropical Paradise v2.2 mode install ---
    10-31-2011 19:27:56 *** Error : script file not correct : C:\Program Files (x86)\Atari\Test Drive Unlimited\TDU Season\Tropical Paradise v2.2\Light roads\Light roads.script ***
    10-31-2011 19:28:12 ===> Exiting Season Mod application <===
    10-31-2011 19:32:31 ===> Launching Season Mod application <===
    10-31-2011 19:33:05 --- Tropical Paradise v2.2 mode install ---
    10-31-2011 19:33:05 *** Error : script file not correct : C:\Program Files (x86)\Atari\Test Drive Unlimited\TDU Season\Tropical Paradise v2.2\Light roads\Light roads.script ***
    10-31-2011 19:33:27 ===> Exiting Season Mod application <===
    10-31-2011 19:33:40 ===> Launching Season Mod application <===
    10-31-2011 19:33:52 ===> Exiting Season Mod application <===
    10-31-2011 19:34:12 ===> Launching Season Mod application <===
    10-31-2011 19:35:11 ===> Exiting Season Mod application <===
    there any way to install it manually?
    what most interests me are the light roads ........... plz help me!!
    [mod edit:] Please do not double or triple post. Use the Edit button instead.
    Hello, bravox09
    To understand better, can you send me the complete log file and the contents of
    Basically, my app checks that all the files indicated inside the script file exist before attempting to run the script. In your case, nothing happens because one or more file is missing.
    I suppose you still have the original file structure with no weird things inside the game ?
    Did you follow carefully the install tips (user rights ?, install season mod after winter mod without having activated the winter mode) ?
    I have to go back in my file structure (it's quite a long time since I used it for the last time) to understand what happened to you. But I definitely need the complete log file.
    Bye
    TD38
    @Carfax
    Hello,
    I suggest you read entirely the first post and the readme file. There is vital informaion inside...
    The most probable cause to your problem (from your description) is that you did not install the Winter Crazy Edition Auto Installer previously.
    If it is not the case, please make a screenshot of the issue.
    TD38
    @Carfax
    Hello,
    TD38
    I downloaded the winter mod and IT says that I need to find the file...!
    EDIT
    BTW how do u take a screenshot?
    @Carfax
    You use the 'printscreen' key on the keyboard to take a screenshot, then paste it inside the windows 'Paint' application ans save it in .jpg format. Retrieve the pictue file and add it as attachment to your post.
    Can you describe IN DETAILS the problem you have (ie write entirely the error you get) ???
    Did you read the 'Readme' files and follow the install procedure for each program, starting with crazy winter auto installer ?
    TD38
    C:\Documents and Settings\Owner.JohnandJennifer\My Documents\My Pictures\problem.JPGDo you want to save this file, or find a program online to open it? I use windows xp and it says that. Anyways when I paste the URL of the pic. and it shows up as an X on the screen. Help!
    :btt:
    When I go find the file online it takes me to the windows file assosiate page. It says that it can't find any file that works with it.
    EDIT:
    Hey BTW I have NET Framework idk which version it is but it works with TDUMT so I'm guessing it's NET Framework 3.0 or higher.
    Oh and I got the pic. Oh wait a minute...F***. I forgot that the damn TDU doesn't even WORK. :bsod:
    You want to save the 2 zip files on your disk, and then open the first one. If you have the proper soft on your computer it should extract everything as an installer... the better is to use 7zip; it's free.
    By the way, you're right, it's better to a a functional TDU before installing any mod :D
    I have Net Framework 3.5.
    TD
    03-14-2012 9:16:03 PM ===> Launching Season Mod application <===
    03-14-2012 9:18:24 PM --- Tropical Paradise v2.2 mode install ---
    03-14-2012 9:18:28 PM --- Backup of installed files ---
    03-14-2012 9:18:28 PM Backuping file : C:\Program Files\Atari\Test Drive Unlimited\Euro\Bnk\Details\RoadPatch.bnk
    03-14-2012 9:18:28 PM Backuping file : C:\Program Files\Atari\Test Drive Unlimited\Euro\Bnk\Level\Hawai\CommonWorld.bnk
    03-14-2012 9:18:30 PM Backuping file : C:\Program Files\Atari\Test Drive Unlimited\Euro\Bnk\Sound\Vehicules\Common.bnk
    03-14-2012 9:18:30 PM Backuping file : C:\Program Files\Atari\Test Drive Unlimited\Euro\Bnk\FrontEnd\HiRes\ConfigPC.bnk
    03-14-2012 9:18:30 PM Backuping file : C:\Program Files\Atari\Test Drive Unlimited\Euro\Bnk\FrontEnd\HiRes\DEMO_END.bnk
    03-14-2012 9:18:30 PM Backuping file : C:\Program Files\Atari\Test Drive Unlimited\Euro\Bnk\FrontEnd\HiRes\GENERAL.bnk
    03-14-2012 9:18:30 PM Backuping file : C:\Program Files\Atari\Test Drive Unlimited\Euro\Bnk\FrontEnd\HiRes\LOG_IN.bnk
    03-14-2012 9:18:30 PM Backuping file : C:\Program Files\Atari\Test Drive Unlimited\Euro\Bnk\FrontEnd\HiRes\map.bnk
    03-14-2012 9:18:30 PM Backuping file : C:\Program Files\Atari\Test Drive Unlimited\Euro\Bnk\FX\Particles.bnk
    03-14-2012 9:18:31 PM Backuping file : C:\Program Files\Atari\Test Drive Unlimited\Euro\Bnk\FX\setbush.2DB
    03-14-2012 9:18:31 PM Backuping file : C:\Program Files\Atari\Test Drive Unlimited\Euro\Bnk\FX\setgrass.2DB
    03-14-2012 9:18:31 PM Backuping file : C:\Program Files\Atari\Test Drive Unlimited\Euro\Bnk\Level\Hawai\Hawai.bnk
    03-14-2012 9:18:31 PM Backuping file : C:\Program Files\Atari\Test Drive Unlimited\Euro\Bnk\FX\FX.ini
    03-14-2012 9:18:31 PM Backuping file : C:\Program Files\Atari\Test Drive Unlimited\Euro\Bnk\FX\Weather.ini
    03-14-2012 9:18:31 PM Backuping file : C:\Program Files\Atari\Test Drive Unlimited\Euro\Bnk\FX\WeatherDesc.ini
    03-14-2012 9:18:31 PM Backuping file : C:\Program Files\Atari\Test Drive Unlimited\Euro\Bnk\FX\HDRIConf.ini
    03-14-2012 9:18:31 PM Backuping file : C:\Program Files\Atari\Test Drive Unlimited\Euro\Bnk\Details\Papers.bnk
    03-14-2012 9:18:31 PM Backuping file : C:\Program Files\Atari\Test Drive Unlimited\Euro\Bnk\FX\Weather_HDRI.ini
    03-14-2012 9:18:31 PM Backup successful of 18 out of 18 files...
    03-14-2012 9:18:31 PM --- Backup Complete---
    03-14-2012 9:18:31 PM --- Now installing 'Tropical Paradise v2.2' mode : Dark roads ---
    03-14-2012 9:18:33 PM Transfering file : C:\Program Files\Atari\Test Drive Unlimited\TDU Season\Tropical Paradise v2.2\Dark roads\RoadPatch.bnk in : C:\Program Files\Atari\Test Drive Unlimited\Euro\Bnk\Details\
    03-14-2012 9:18:34 PM *** Installation stopped ***
    03-14-2012 9:18:44 PM --- Tropical Paradise v2.2 mode install ---
    03-14-2012 9:18:47 PM --- Backup of installed files ---
    03-14-2012 9:18:47 PM Backuping file : C:\Program Files\Atari\Test Drive Unlimited\Euro\Bnk\Details\RoadPatch.bnk
    03-14-2012 9:18:47 PM *** Error : Ubnknown exception catched during backup procedure ***
    03-14-2012 9:18:47 PM --- Now installing 'Tropical Paradise v2.2' mode : Light roads ---
    03-14-2012 9:18:48 PM Transfering file : C:\Program Files\Atari\Test Drive Unlimited\TDU Season\Tropical Paradise v2.2\Light roads\RoadPatch.bnk in : C:\Program Files\Atari\Test Drive Unlimited\Euro\Bnk\Details\
    03-14-2012 9:18:48 PM *** Installation stopped ***
    03-14-2012 9:19:01 PM --- User forces restoration ---
    03-14-2012 9:19:01 PM --- Restoration ---
    03-14-2012 9:19:01 PM Transfering file : C:\Program Files\Atari\Test Drive Unlimited\TDU Season\Standard mode\Restoration TDU Normal Mode\RoadPatch.bnk in : C:\Program Files\Atari\Test Drive Unlimited\Euro\Bnk\Details\
    03-14-2012 9:19:01 PM *** Restoration failed ***
    03-14-2012 9:19:11 PM --- Japanese Autumn v2.0 mode install ---
    03-14-2012 9:19:12 PM --- Backup of installed files ---
    03-14-2012 9:19:12 PM Backuping file : C:\Program Files\Atari\Test Drive Unlimited\Euro\Bnk\Details\RoadPatch.bnk
    03-14-2012 9:19:12 PM *** Error : Ubnknown exception catched during backup procedure ***
    03-14-2012 9:19:12 PM --- Now installing 'Japanese Autumn v2.0' mode : Default ---
    03-14-2012 9:19:14 PM Transfering file : C:\Program Files\Atari\Test Drive Unlimited\TDU Season\Japanese Autumn v2.0\Default\CommonWorld.bnk in : C:\Program Files\Atari\Test Drive Unlimited\Euro\Bnk\Level\Hawai\
    03-14-2012 9:19:15 PM Installation complete of : 1 files...
    03-14-2012 9:19:15 PM --- Installation complete of 'Japanese Autumn v2.0' mode : Default ---
    03-14-2012 9:19:17 PM --- Installation of : Maciuk's weather mod ---
    03-14-2012 9:19:17 PM Transfering file : C:\Program Files\Atari\Test Drive Unlimited\TDU Season\Weather mods\Maciuk's weather mod\Weather.ini in : C:\Program Files\Atari\Test Drive Unlimited\Euro\Bnk\FX\
    03-14-2012 9:19:17 PM *** Installation of lighting files failed ***
    03-14-2012 9:19:19 PM *** Installation stopped ***
    03-14-2012 9:19:25 PM --- Japanese Autumn v2.0 mode install ---
    03-14-2012 9:19:25 PM --- Other Japanese Autumn v2.0 mode is active, need to partially restore before installing ---
    03-14-2012 9:19:27 PM Transfering file : C:\Program Files\Atari\Test Drive Unlimited\TDU Season\Standard mode\Restoration TDU Normal Mode\RoadPatch.bnk in : C:\Program Files\Atari\Test Drive Unlimited\Euro\Bnk\Details\
    03-14-2012 9:19:27 PM *** Installation stopped ***
    03-14-2012 9:21:09 PM --- Restoration ---
    03-14-2012 9:21:09 PM Transfering file : C:\Program Files\Atari\Test Drive Unlimited\TDU Season\Standard mode\Restoration TDU Normal Mode\RoadPatch.bnk in : C:\Program Files\Atari\Test Drive Unlimited\Euro\Bnk\Details\
    03-14-2012 9:21:09 PM *** Restoration failed ***
    03-14-2012 9:24:14 PM --- Tropical Paradise v2.2 mode install ---
    03-14-2012 9:24:14 PM --- Other mode is active (Japanese Autumn v2.0), need to partially restore before installing ---
    03-14-2012 9:24:20 PM Transfering file : C:\Program Files\Atari\Test Drive Unlimited\TDU Season\Standard mode\Restoration TDU Normal Mode\RoadPatch.bnk in : C:\Program Files\Atari\Test Drive Unlimited\Euro\Bnk\Details\
    03-14-2012 9:24:20 PM *** Installation stopped ***
    03-14-2012 9:25:12 PM --- Tropical Paradise v2.2 mode install ---
    03-14-2012 9:25:12 PM --- Other mode is active (Standard Mode), need to partially restore before installing ---
    03-14-2012 9:25:16 PM Transfering file : C:\Program Files\Atari\Test Drive Unlimited\TDU Season\Standard mode\Restoration TDU Normal Mode\RoadPatch.bnk in : C:\Program Files\Atari\Test Drive Unlimited\Euro\Bnk\Details\
    03-14-2012 9:25:16 PM *** Installation stopped ***
    03-14-2012 9:25:22 PM --- Restoration ---
    03-14-2012 9:25:22 PM Transfering file : C:\Program Files\Atari\Test Drive Unlimited\TDU Season\Standard mode\Restoration TDU Normal Mode\RoadPatch.bnk in : C:\Program Files\Atari\Test Drive Unlimited\Euro\Bnk\Details\
    03-14-2012 9:25:22 PM *** Restoration failed ***
    03-14-2012 9:26:49 PM ===> Launching TDU <===
    03-14-2012 9:33:48 PM --- Restoration ---
    03-14-2012 9:33:48 PM Transfering file : C:\Program Files\Atari\Test Drive Unlimited\TDU Season\Standard mode\Restoration TDU Normal Mode\RoadPatch.bnk in : C:\Program Files\Atari\Test Drive Unlimited\Euro\Bnk\Details\
    03-14-2012 9:33:48 PM *** Restoration failed ***
    Please help me on this issue. I've installed the crazy winter mod and the addon season mod into the TDU Directory. I tried to patch it with DarkRoads with the Island Paradise and the Weather mod. It successfully backups, but fails on the DarkRoads. I tried to restore it, but it failed. This is the complete log and problems I have encountered. I am a noob at this so please cut me some slack.
    Hello,
    The most probable cause of your issue is that you forgot to set the "Write" rights on your TDU folders and subfolders... the app is able to take the files, but not to put them in TDU folders.
    Have a look to the readme file, and make sure you gave the write access to "C:\Program Files\Atari\Test Drive Unlimited" and the subfolders...
    Then you must restore before asking the app to do any other mod installation.
    Please tell me if it works better after.
    TD38
