iLLusion: Island Paradise v0.9.5 + Autumn and Winter Add-On
iLLusion
  • Replies 859
Well, i just went my TDU without any mods, then i installed the patch 1.68b and right after the island paradise and it finally complete the installation. The unique reason what i can think it's a conflict between v0.89 and v0.95... Lol
Sorry, I wasn't active on TDU:C lately so I'm a bit late to help you. Luckily, you've figured out by yourself. Yay! You've made it. :) Enjoy Milli.
@NebooNu
You failed to read the INFO file is all I can say. :D
@Doctor G.
You're welcome!
@Aston007
I've seen you've posted some WA pics in your photothread, that means you've solved the issue? :)
@SunseT
You can find all of your backups in TDU/Mods folder under the IPv095, IPAAv095 or IPWA095. Depends on what you've installed first.
Sorry guys, I've been busy lately so I don't have time to help you out right now. I'll get back to you as soon as I can. ;)
I just installed the mod. It said "can´t install because a critical error occured"...I started TDU and the mod seems to be installed. no problem with map.
But where is the uninstall button?! It doesn´t work.
Of course uninstall won't work, you said it yourself - critical error occured during the installation. Post your patch.txt here.
I can´t attach it, it says "invalid file"... :mad:
so here is the whole text:
"Log C:\Dokumente und Einstellungen\Bjoern\Desktop\iLLusion - Island Paradise v0.9.5\iLLusion - Island Paradise v0.9.5\iLLusion - Island Paradise v0.9.5\patch.log
Enabled : True
Events : 119
Has new event : True
> 26.12.2010 14:51:19 - Running patch C:\Dokumente und Einstellungen\Bjoern\Desktop\iLLusion - Island Paradise v0.9.5\iLLusion - Island Paradise v0.9.5\iLLusion - Island Paradise v0.9.5\patchs\install.pch - 377 instruction(s).
> 26.12.2010 14:51:19 - Chosen install groups: [Full Edition].
> 26.12.2010 14:51:19 - Running instruction #1 from group 'Full Edition': ...
> 26.12.2010 14:51:19 - Running instruction #2 from group 'Full Edition': ...
> 26.12.2010 14:51:19 - Running instruction #3 from group 'Full Edition': ...
> 26.12.2010 14:51:19 - Running instruction #4 from group 'Full Edition': ...
> 26.12.2010 14:51:19 - Running instruction #5 from group 'Full Edition': ...
> 26.12.2010 14:51:21 - Running instruction #6 from group 'Full Edition': ...
> 26.12.2010 14:51:23 - Running instruction #7 from group 'Full Edition': ...
> 26.12.2010 14:51:25 - Running instruction #8 from group 'Full Edition': ...
> 26.12.2010 14:51:26 - Running instruction #9 from group 'Full Edition': ...
> 26.12.2010 14:51:28 - Running instruction #10 from group 'Full Edition': ...
> 26.12.2010 14:51:30 - Running instruction #11 from group 'Full Edition': ...
> 26.12.2010 14:51:32 - Running instruction #12 from group 'Full Edition': ...
> 26.12.2010 14:51:34 - Running instruction #13 from group 'Full Edition': ...
> 26.12.2010 14:51:35 - Running instruction #14 from group 'Full Edition': ...
> 26.12.2010 14:51:37 - Running instruction #15 from group 'Full Edition': ...
> 26.12.2010 14:51:39 - Running instruction #16 from group 'Full Edition': ...
> 26.12.2010 14:51:41 - Running instruction #17 from group 'Full Edition': ...
> 26.12.2010 14:51:43 - Running instruction #18 from group 'Full Edition': ...
> 26.12.2010 14:51:45 - Running instruction #19 from group 'Full Edition': ...
> 26.12.2010 14:51:46 - Running instruction #20 from group 'Full Edition': ...
> 26.12.2010 14:51:48 - Running instruction #21 from group 'Full Edition': ...
> 26.12.2010 14:51:50 - Running instruction #22 from group 'Full Edition': ...
> 26.12.2010 14:51:52 - Running instruction #23 from group 'Full Edition': ...
> 26.12.2010 14:51:54 - Running instruction #24 from group 'Full Edition': ...
> 26.12.2010 14:51:55 - Running instruction #25 from group 'Full Edition': ...
> 26.12.2010 14:51:57 - Running instruction #26 from group 'Full Edition': ...
> 26.12.2010 14:51:59 - Running instruction #27 from group 'Full Edition': ...
> 26.12.2010 14:52:01 - Running instruction #28 from group 'Full Edition': ...
> 26.12.2010 14:52:03 - Running instruction #29 from group 'Full Edition': ...
> 26.12.2010 14:52:05 - Running instruction #30 from group 'Full Edition': ...
> 26.12.2010 14:52:07 - Running instruction #31 from group 'Full Edition': ...
> 26.12.2010 14:52:08 - Running instruction #32 from group 'Full Edition': ...
> 26.12.2010 14:52:10 - Running instruction #33 from group 'Full Edition': ...
> 26.12.2010 14:52:12 - Running instruction #34 from group 'Full Edition': ...
> 26.12.2010 14:52:14 - Running instruction #35 from group 'Full Edition': ...
> 26.12.2010 14:52:16 - Running instruction #36 from group 'Full Edition': ...
> 26.12.2010 14:52:18 - Running instruction #37 from group 'Full Edition': ...
> 26.12.2010 14:52:20 - Running instruction #38 from group 'Full Edition': ...
> 26.12.2010 14:52:21 - Running instruction #39 from group 'Full Edition': ...
> 26.12.2010 14:52:23 - Running instruction #40 from group 'Full Edition': ...
> 26.12.2010 14:52:25 - Running instruction #41 from group 'Full Edition': ...
> 26.12.2010 14:52:27 - Running instruction #42 from group 'Full Edition': ...
> 26.12.2010 14:52:29 - Running instruction #43 from group 'Full Edition': ...
> 26.12.2010 14:52:30 - Running instruction #44 from group 'Full Edition': ...
> 26.12.2010 14:52:32 - Running instruction #45 from group 'Full Edition': ...
> 26.12.2010 14:52:34 - Running instruction #46 from group 'Full Edition': ...
> 26.12.2010 14:52:36 - Running instruction #47 from group 'Full Edition': ...
> 26.12.2010 14:52:37 - Running instruction #48 from group 'Full Edition': ...
> 26.12.2010 14:52:39 - Running instruction #49 from group 'Full Edition': ...
> 26.12.2010 14:52:41 - Running instruction #50 from group 'Full Edition': ...
> 26.12.2010 14:52:43 - Running instruction #51 from group 'Full Edition': ...
> 26.12.2010 14:52:44 - Running instruction #52 from group 'Full Edition': ...
> 26.12.2010 14:52:46 - Running instruction #53 from group 'Full Edition': ...
> 26.12.2010 14:52:48 - Running instruction #54 from group 'Full Edition': ...
> 26.12.2010 14:52:50 - Running instruction #55 from group 'Full Edition': ...
> 26.12.2010 14:52:51 - Running instruction #56 from group 'Full Edition': ...
> 26.12.2010 14:52:53 - Running instruction #57 from group 'Full Edition': ...
> 26.12.2010 14:52:55 - Running instruction #58 from group 'Full Edition': ...
> 26.12.2010 14:52:57 - Running instruction #59 from group 'Full Edition': ...
> 26.12.2010 14:52:59 - Running instruction #60 from group 'Full Edition': ...
> 26.12.2010 14:53:00 - Running instruction #61 from group 'Full Edition': ...
> 26.12.2010 14:53:02 - Running instruction #62 from group 'Full Edition': ...
> 26.12.2010 14:53:04 - Running instruction #63 from group 'Full Edition': ...
> 26.12.2010 14:53:05 - Running instruction #64 from group 'Full Edition': ...
> 26.12.2010 14:53:07 - Running instruction #65 from group 'Full Edition': ...
> 26.12.2010 14:53:09 - Running instruction #66 from group 'Full Edition': ...
> 26.12.2010 14:53:11 - Running instruction #67 from group 'Full Edition': ...
> 26.12.2010 14:53:13 - Running instruction #68 from group 'Full Edition': ...
> 26.12.2010 14:53:14 - Running instruction #69 from group 'Full Edition': ...
> 26.12.2010 14:53:17 - Running instruction #70 from group 'Full Edition': ...
> 26.12.2010 14:53:18 - Running instruction #71 from group 'Full Edition': ...
> 26.12.2010 14:53:20 - Running instruction #72 from group 'Full Edition': ...
> 26.12.2010 14:53:22 - Running instruction #73 from group 'Full Edition': ...
> 26.12.2010 14:53:24 - Running instruction #74 from group 'Full Edition': ...
> 26.12.2010 14:53:25 - Running instruction #75 from group 'Full Edition': ...
> 26.12.2010 14:53:28 - Running instruction #76 from group 'Full Edition': ...
> 26.12.2010 14:53:28 - Running instruction #77 from group 'Full Edition': ...
> 26.12.2010 14:53:28 - Running instruction #78 from group 'Full Edition': ...
> 26.12.2010 14:53:28 - Running instruction #79 from group 'Full Edition': ...
> 26.12.2010 14:53:28 - Running instruction #80 from group 'Full Edition': ...
> 26.12.2010 14:53:30 - Running instruction #81 from group 'Full Edition': ...
> 26.12.2010 14:53:31 - Running instruction #82 from group 'Full Edition': ...
> 26.12.2010 14:53:33 - Running instruction #83 from group 'Full Edition': ...
> 26.12.2010 14:53:35 - Running instruction #84 from group 'Full Edition': ...
> 26.12.2010 14:53:37 - Running instruction #85 from group 'Full Edition': ...
> 26.12.2010 14:53:38 - Running instruction #86 from group 'Full Edition': ...
> 26.12.2010 14:53:40 - Running instruction #87 from group 'Full Edition': ...
> 26.12.2010 14:53:42 - Running instruction #88 from group 'Full Edition': ...
> 26.12.2010 14:53:44 - Running instruction #89 from group 'Full Edition': ...
> 26.12.2010 14:53:45 - Running instruction #90 from group 'Full Edition': ...
> 26.12.2010 14:53:47 - Running instruction #91 from group 'Full Edition': ...
> 26.12.2010 14:53:49 - Running instruction #92 from group 'Full Edition': ...
> 26.12.2010 14:53:51 - Running instruction #93 from group 'Full Edition': ...
> 26.12.2010 14:53:53 - Running instruction #94 from group 'Full Edition': ...
> 26.12.2010 14:53:53 - Running instruction #95 from group 'Full Edition': ...
> 26.12.2010 14:53:54 - Running instruction #96 from group 'Full Edition': ...
> 26.12.2010 14:53:56 - Running instruction #97 from group 'Full Edition': ...
> 26.12.2010 14:53:58 - Running instruction #98 from group 'Full Edition': ...
> 26.12.2010 14:54:00 - Running instruction #99 from group 'Full Edition': ...
> 26.12.2010 14:54:01 - Running instruction #100 from group 'Full Edition': ...
> 26.12.2010 14:54:03 - Running instruction #101 from group 'Full Edition': ...
> 26.12.2010 14:54:05 - Running instruction #102 from group 'Full Edition': ...
> 26.12.2010 14:54:07 - Running instruction #103 from group 'Full Edition': ...
> 26.12.2010 14:54:09 - Running instruction #104 from group 'Full Edition': ...
> 26.12.2010 14:54:10 - Running instruction #105 from group 'Full Edition': ...
> 26.12.2010 14:54:10 - Running instruction #106 from group 'Full Edition': ...
> 26.12.2010 14:54:11 - Running instruction #107 from group 'Full Edition': ...
> 26.12.2010 14:54:11 - Running instruction #108 from group 'Full Edition': ...
> 26.12.2010 14:54:11 - Running instruction #109 from group 'Full Edition': ...
> 26.12.2010 14:54:12 - Running instruction #110 from group 'Full Edition': ...
> 26.12.2010 14:54:15 - Running instruction #111 from group 'Full Edition': ...
> 26.12.2010 14:54:17 - Running instruction #112 from group 'Full Edition': ...
> 26.12.2010 14:54:19 - Running instruction #113 from group 'Full Edition': ...
> 26.12.2010 14:54:19 - Exception spotted: Could not find file 'C:\SPIELE\TDU\\Euro\Bnk\Details\Papers.bnk'.
> 26.12.2010 14:54:19 - Instruction #113 ended with error.
> 26.12.2010 14:54:19 - Patch halted because of an error.
> 26.12.2010 14:54:19 - No collected messages.
Well, here's your problem.
My guess is that you've probably deleted Papers.bnk from that folder, so installer can't find and replace that file, hence the error.
Ever since we learned that by deleting stuff from Details folder will give us few more fps, a lot of people made that mistake. It's 2011 already people, it's about time to update your hardware. :p
Anyway, either copy your original Papers.bnk if you have it in backup somewhere, or use the one from IP.
Small suggestion though, you already have broken IP installed, so installing it again, and then uninstalling won't help you much because you'll still be stuck with those broken IP files. There's a solution, but you'll have to manually replace files from TDU\Mods\IPv095 folder first.
Good luck. ;)
