Indicators on dashboard - various cars (14)
thunderhawk17382
  • Replies 117
As you wrote in your pm, the replaced files don't show any changes. - It seems that the game is using the original files instead of the unpacked files.
It is mandatory to run the game unpacked!
And I've got a suspicion. I don't know if it is related to ...
You don't need to unpack bnk to instal mods, just unpack your game :
Follow this tutorial (Thanks to Speeder)
===> http://tdu2wiki.host56.com/index.php/How_to_extract_your_game
So I need to have the explo version? I've installed it but, I'm using a crack which has an older version.
I don't know, how i should help in this case. - Sorry
Best regards,
Stefan
Best regards,
Stefan
Thanks anyway, but now I have a different problem. Please read this thread of mine: http://forum.tdu-central.com/threads/27733-TDU2-DLC-EXPLO-v-027-has-stopped-working-HELP!
OK, it works, I did a mistake, that's all :))
Yes - there is! This is next on my list! :D ... By the way ... clicked the "+rep-button" a few times on "bug-reports" ;)
Seems that another material-setting is messed-up on 458. Research starts now!
Edit: Copied material-settings from orignial file, for the interior-glass ("engine-window"). Should be fixed now.
458 v0.2 in first posting.
Edit2: Audi Q7 v0.4 -- "indicators brighter while lights on" should be fixed
best regards,
Stefan
Uploaded Ferrari 458 v0.3 - grills beside the rear-window should be fixed.
Thanks for report and the pictures! - But as i had asked before ... Do you mean the inside of the exhaust-pipes or the exhaust in general?
Because on your left picture, the car stand in shadow and every chrome-part is dark (badges, exhaust) - on the right picture car doesn't stand in the shadow and badges+exhaust looks glossy/shiny (of course it's nearly white).
I will have a look. ;)
Edit: As I had already thought, only the "inner pipes" (wich should be dark/black) are messed up. Have to check the material, cause the complete exhaust is only one material (chrome)!
Perhaps there is a new version tomorrow. ;)
Edit2: Also started ML 63 today :)
Edit3: 458 inner exhaust pipes - did a quick test, without success. :( will try to "change" the inner part to black.
greetz
I mean the inside of the exhaust pipe but also on the outside should look srebne not white.
EDIT: Uploaded Ferrari 458 v0.3 - grills beside the rear-window should be fixed - nothing has changed still the same bug as of version 0.2
