Questions to modders
TurboDorifto
Hey guys, i just have some questions to you, modders :)
at first, how i can "lower" the car in zmodeler? which dummy i have to move?
how i can change the tire/rimsize? i want to make them smaller for example.
and how i can camber(angle) the wheels?
i already know how to move the wheels around for more offset or else.
thanks for your answers already! :)
greets
Fork_xx are the dummies for the rims. One of the dummies in it is responsible for the dimensions of the rims. Scale them for a bigger wheel (tire+rim) and rotate them for camber. If you scale the tire (which is another dummy) there will rather be a gap between rim and tire (if you scale it up) or the tyre will be inside the rim (if you scale it down) so i dont recommend you to scale the tire dummy at all.
