TDU2 VPE tdu2 vpe the file "db_data.cpr" can not be found. TDU2VPE will terminate. Help me
felaket639
help me
Please double check whether the contents of "TDU 2 Root folder" of "Settings" is correct.
The VPE in the folder you indicated with "new error" is ver 3.2.4.0. It seems that there are probably different versions in two places. The file size of ver3.5.0.5 is 5662 Kb. Please confirm, and use properly version.
And, important thing; It is desirable to put all vpe's files to the newly created folder outside of "Program Files" or "Program Files (x86)".
