TDU TEXTURE MOD: Aston Martin DB9 Volante Headlight Texture
Aston Martin DB9 Volante Modded Headlight Texture by MCiN7
(looks good on any color DB9 Volante)
!TESTED ONLINE!
Pics: (Click for bigger image)
Download:
BNK File Editor
MCiN7 DB9 Vol Headlight Texture
This is just a little texture, Thanks to 'stopp!ng' for the original idea aswell as 'WROOM'.
Instructions1:
Items needed:
BNK File Editor by Jeffrey Harris
lgt_fof.2db by MCiN7
Instructions2:
1. Extract 'bnkfileeditor.zip' to any location (desktop is usually the easiest)
2. Extract 'DB9_Vol_Headlight_Texture.zip' to any location (desktop is usually the easiest)
3. Open BNK File Editor
4. Click on 'Open BNK...'
5. Navigate to (Default)'C:\Program Files\Atari\Test Drive Unlimited\Euro\Bnk\Vehicules'
6. Find and Select 'DB9_Vol.bnk'
7. Click 'Open'
8. Find and select 'lgt_fof.2db'
9. Click on 'Replace Selected File...'
10. Navigate to the place you extracted 'DB9_Vol_Headlight_Texture.zip'
11. Select 'lgt_fof.2db'
12. Click 'Open'
13. Click 'OK'
14. Click 'Save BNK'
Oops, I forgot Andreaz, about the lights, I'll get those up tonight :)
Thanks MCiN7 for this mod :)
I'll try and get some more links up soon :)
DB9 Volante Headlight Mod
New Headlights for the Db9 Volante!
Creator: MCiN7
[Download]
Place this is in C:\Program Files\Atari\Test Drive Unlimited\Euro\Bnk\Vehicules'.
Click to Enlarge
http://i149.photobucket.com/albums/s79/IcedBullet/Test%20Drive%20Unlimited/Mods/thdb_vol_light_1.jpg http://i149.photobucket.com/albums/s79/IcedBullet/Test%20Drive%20Unlimited/Mods/thdb_vol_light_2.jpg
Indicators is technically the right word, but we get you :)
I think it would be quite hard, and would probably require hacking into the game coding. I mean, looking at the LP640 mod, although the reverse light lens cover is in a different place, that actual light comes from the same place as the normal Murcielago.
Having said that, WROOM made different coloured headlight, so it may be possible to actually change the actual lights.
But I expect one of our more experienced modders will give you a better idea of what is/isn't possible :)
Front/Rear Light tints?
I saw IB's thread with Lambo changed rear lights and DTM with blacked out rear lights.
Is it possible to do this to any car or does someone have to create a file to replace the original?
Because I'd love to black out the rear lights on certain cars :D
Thanks Maxx.
i'd like headlights that you could leave on without going into any instant challenges. also beams so you can actually see the road in the dark. night mod is great but in a forest road area seeing a black car is impossible also just seeing the road in these areas is pretty difficult. especially at high speed.
If you set headlights to say 'enter' then on your keyboard, rest a book on the bottom right key, then in the options, turn off instant challenge :)
Then you get permanent lights without challenging people :D
