Ford Focus SVT - HUD [V1.0]
Creator: 24stdzocker
Credits: HUD originaly from TDU, Mazda MX5
-- OLD IMAGE REMOVED (imageshack) ---- OLD IMAGE REMOVED (imageshack) ---- OLD IMAGE REMOVED (imageshack) ---- OLD IMAGE REMOVED (imageshack) --
!!Please make sure to backup your original files before installing this mod and read the included README file if there is one!!
Download: Megaupload
(Just type in the Code in the upper right corner)
Requires Djey's Magicmap
Mod History
v1.0 - Released
Terms of use:
- The models, skins and other files are for private use only
- Commercial use of this modification is strictly prohibited
- All Registered Trademarks and Copyrights are property of their respective owners
Optional Terms
- You are allowed to edit this modification and it's contents for your own private use
- You are allowed to post this modification on your own site with a Link to this Page
Hey Guys,
I'm posting my first mod here for now, hoping you'll have Fun with it ;)
Just for an explanation if someone gets confused why this HUD isn't 100% correct like the real one:
When I was driving Tool's SVT today I experemented a bit with some Gauges which TDU not used,
after I've seen that the MX5 Gauge has most likely the same Layout like that one from the SVT Focus
I started colouring it right and made the .ini fit the 7000rpm rev in the Audi A3 (which I had replaced).
I've also added an SVT Badge onto the Int_rpm. The Gauges should show 100% correct kmh, mph and rpm
(as you can see). They turned out good so I decided to share them. Ingame the Gauges also should be round,
unlike in my Pictures, that's just a stupid effect because I'm having a 16:10 resolution :eek:
Oh and, if you find any Bug's just report them :)
Greetz,
24stdzocker
Comments please :D
Thanks, but as I explained they don't used to be 100% realistic, because they are based on TDU's MX5's Gauges ;)
They are still better than the standart A3 Gauges I think.
I guess you could make them better, but your HUD's are handmade and I'm not so used to Photoshop for doing that :p
But in time I'll try to do a more realistic Needle, if that's the problem...
No, this is not the problem, it's ok and better than the standard Audi HUD...
When I have some free time, I'll do a handmade HUD perhaps, but first I have to do some other things ... ;)
Nice HUD...
Greetz
Fl0w
