Pedals Not Recognized (Help)
SteveR_52
The quick and easy:
I have a G25 (not the problem) with a set of CST High-End pedals connected via USB (http://www.cannonsimulationtechnologies.com). This setup works for every sim/game I have except this one. When I go to calibrate the pedals nothing happens. I push the pedals, hold the pedals, invert the pedals, it doesn't even say anything. Just said "enter desired axis" or whatever.
These pedals are not integrated into my G25, therefore are a separate controller altogether. Is this the issue? Does TDU only recognize one controller?
I've done some searching around this and other forums and have seen a LOT of pedal problems with this game, but this seems different.
Any ideas? Can I manually assign the axis through an INI file somewhere?
(I hope I didn't just spend 45EUR and downloaded this for 2 hours to find out I can't play... :cry: )
