Problem when Exporting [ZModeler 2.2.1]
Lazerchicken
Hi !
I need some skilled modder's help.
I have been trying to convert a mod for TDU (using Zmodeler 2.2.1) for a while now, and after having followed the normal process (merging with old model, changing material to PAINT, etc...), I try to export it, and then Zmod says that :
Scene does not contain node "911" for export. Whole scene will be exported.
Can't determine gloss-light texture layer in material [96 94 9F E 84 86]_D marked as "GLT".
Failed to convert material for export file:TestDriveBNKExport.cpp line:203
Failed to find layers info for configuration 0x10000000 in material FRL_W file:materialsExport.cpp line:859
What I find in the target directory is a only *.3dg file, which weights 0 kB...
Thanks to the one who will light me ;)
but let take it step by step ok ?
the models are in 3dg ok ? so 3dg(not extension just the file) is made by eden games , and 2db files too , so the model is made to work with 2db files not dds . its right modders ?
and can you mod again something and when you finish copy all error log then we can give more exactly answers !
Offtopic: Anyway i like eiffel tower . i think you live in paris right ?
