to check your RAM:
1. Click the Start button
2. Go to "Run"
3. Type in " dxdiag" (with no quotation marks)
4. A window will pop up. Under the system tab, look for Memory. and the number you have there is how much RAM you have! (Ex: mine says 1534mb RAM or 1.5gb)
to add more RAM, just buy at your computer store. to see what kind of RAM you have I recommend downloading this program that tells you what hardware you have on your computer. It's called EVEREST Home Edition.
yes that man from the Phillipines, hes right, you need to buy it, if its saying you dont have enough memory then you probly have max like 256MB, cuz i run TDU full detail 4X AA with 512 MB ram, AMD athlon 3200+ 2.0ghz and a 7600GS
