My G25 is finnaly coming (no local store so internet was again my best friend).
What are the best settings INGAME and via the Logitech Setup for the best TDU experiance. I like force feedback alot. Also the steering wheel should make some resistance. But at which value's must I put linarity etc?
If you leave everything on default you should be fine with the forces. And of course you shouldn't use the centering spring. I recommend you use seperate axis for brake and accelerator. As for the degrees of rotation, if you use 180-210 have the linearity slider near the center. 900 degrees works well with the slider at the far right. Or left... I can't test it right now so do a little test, and see. I personally use 210 degrees because TDU doesn't natively support 900 and the whole thing feels funny.
Hope this helps.
cheers
