Ferrari 288 GTO beta sound mod
Doctor G.
I would have posted this in the betas but for some reason i cannot start a new thread there, so I post it here...
I've found a DVD with some onboard footage of a F288 GTO (ultra rare stuff :D) :
...and I tried to make a sound mod with it :
https://www.youtube.com/watch?v=ZFZLYwwpbDI
http://www.youtube.com/watch?v=ZFZLYwwpbDI
But the result is half satisfying :
First, it may not sound so realistic when the car goes fast.
This is due to the fact that the high rpm loop is based on a middle rpm sample (as the car never reaches very high speeds in the video). Plus the onhigh sample is not very long, so I had to copy and paste to make it longer which is not very good...
Second, I am not sure if it's high pitched enough.
Looks like the driver is going easy on the throttle and maybe he doesn't push the needle to the max, which means that I should set a higher tone to the sound mod (because he higher tone of the mod is based from the higher tone that the car reaches in the video). But if i do this, the result sounds really ridiculous (it's already weird, i would have used another recording if I had one), more like a Vespa than a sportcar and then I prefer to not release it.
For example, in that other video, it sounds more high pitched when the guy push the throttle at 2:38 (and he doesnt even push it to the max) :
oKRhFVV-BiU
http://www.youtube.com/watch?v=oKRhFVV-BiU
What do you think? Shall I leave it like it is, or forget the idea to make a sound from this video? (Which probably means that no real sound for the F288 will be made until a long time, I don't even think it has ever been done before).
Thanks for help.
[mod edit:] Please only embed a maximum of 2 videos per post, thanks!
If you really want a good DVD series to get car sounds from, look for the series called Victory By Design. They have several to choose from including Alfa-Romeo, Aston Martin, Ferrari, Jaguar, Lotus, Maserati, and Porsche.
Some of the video sections are on youtube, just not the whole things.
