TDUPE help with modding vehicle performance.
willhub
Hi.
I'm stuck with modding vehicle performance.
I have one vehicle, I'm trying to make it go very fast, like 350mph but not with super mad acceleration and decent gear changes, the problem is that the gear ratios appear to need modding as it's doing 180mph in 1st gear and I don't want that, then wheny you get to 6th gear it's down at 3 revs and just crawls up so slow and just seems odd.
Also I have a 4x4 vehicle that I want to make more like a 4x4, it's on the Audi A3, I want to be able to modify it so it can go up hills better than a normal car, like 4x4's can, and those steep hills that all cars in the game struggle to get up this will.
I also want it to have better gear changes and lower acceleration, sort of 0-30mph in 1st and so on, at a reasonable gap.
The other problem is with the clutch, for some reason using the clutch the revs just go up, rather than down which is how it should be, at near 4 revs they just go up, and if I'm around 3 revs then it stays around there.
Any ideas on how to mod these 2 vehicles with the performance characteristics I want, naturally I'd want the 4x4 to be heavier and with 4x4 like handling.
Thanks.
