Car spin out of control when hit curb?
Guest Aussie.Guy
How do i edit the physics to stop my car from spinning out of control?
I tried the suspension rate and damper but none of it seemed to help.
DOes anyone have a good suggestion for setting up suspension and damper to counteract the spinning out of control when driving at high speed and hitting the side of the road beit dirt or curb?
You don't. There's nothing you can do to any suspension settings to prevent the car from doing anything bad when you drop tires 8 to 10 inches off the curb into the grass.
Best suggestion.....
Don't hit the curb in the first place.
try to modfiy this:
Oversteer : 95
Grip : 1015
Center of Gravity : X+2 or try X+3 or more if it continue to get out of control
(X is what you have now)
(ex: x=50 => center of gravity 55)
Good Luck!
None of that is going to work when he drops off a 10 to 12 inch curb, no suspension setting can counteract that much camber change, especially at speed.
This isn't Initial D, so trying that "tires hooked into the curb" thing doesn't work, not even in real life, it only results in damaged suspension and steering components.
