Hi folks!
Well, I have a problem :D I want to modify my vehicles, but the problem is, that every time when I want to modify something, I can't modify it.
It says: unable to load requested vehicle data
So what's the problem ?
Thanks for all the help!
Greets
Vehicle Manager shows error when loading vehicle data on Turkish PCs
Switch Windows regional settings (keyboard, culture) to English.
Vehicle Manager shows error when loading vehicle data, any vehicle
It might be an issue with your cameras.bin file. Please overwrite following file: <TDU path>\euro\bnk\database\cameras.bin by the one provided with TDUMT in xml\default folder.
Unable to edit a particular vehicle in Vehicle Manager
You may have modified max speed with Dredgy’s PE, above server-authorized limit. Restore default value before using TDUMT on this vehicle.
Above solutions don’t work.
Switch to Debug mode (via Settings panel), restart the app then make it crash again. Then provide contents from xxxxxxxx.log files which have appeared in TDUMT folder. It’s applicable to auto installers as well (debug mode is already active on those).
Thanks for your advices, but none of them work :S So it looks like I don't have the luck to mod with TDUMT.
Thanks anyway!!!!!
Greetings, Marko!
I tried the 4th option but the xxxxxxx file doesn't come up in my TDUMT folder, so I can't really help myself with this...
It also says: TDU main folder not set properly.
And now it also says: Can't open Vehicle Manager.
It's gettin' worse and worse...
Greetings
xxxxxxx is just a sample I gave, not a real file :D
don't you have a ModdingToolsDebug.log (make sure you have debug mode enabled) ?
'TDU main folder not set properly.' > so please check and set it eventually :)
  • 3 years later...
hi i also try to play with same cars ... but now my problem is that tdu moding dose not find [ db.bnk ] ... neither i , searched for it after a full unpack , before and after strted the game ... and nothing , can same one upload one for me ? thancks in advance
