I think so, i have not tried this method, but i believe it should work.
Download the MiniBNK Manager from this forum
Open the BNK Manager and click the three dots at the top right coner
Then:
1) Go to \Atari\TDU2\Euro\bnk\Sound\Radio\Music (Select any of these music BNK files)
2) Click "Load" in the top right corner
3) Click the "Unpack all" button and make a new folder in your documents and call it whatever you want (DO NOT CLOSE THE BNK MANAGER)
4) Go to the directory where you just saved that
5) Get your own music (I believe it has to be a .WAV file, 44khz and 4-bit depth for it to work)
6) Put your own .WAV file and delete the old one (Maybe use the exact same name for the song, try this after if this does not work)
7) Go back to the BNK Manager and click "Repack" and select the folder you created with your custom song and overwrite the BNK file you just modified
Try it out... I am not absolutely certain this will work, but may aswell give it a go
Donga.
