TDU - every single vehicle delivery mission reduces reward without collisions
Does anyone know why every single vehicle delivery mission at some point reduces the reward on an even road and even when there were no collisions? It wasn't like that years ago when I last played TDU. It's really annoying, the road is even, I'm doing about 160 (100 mph) in order to avoid collisions and yet at random moments the reward of $90,000 starts to drop for apparent reason. I even resorted to removing the traffic because I thought it was a bug caused by it but the problem remained.
Posted (edited)
Are you playing above 60 FPS? There's been a weird history with this game of having a variety of physics bugs related to playing over 60 FPS, including collisions with invisible traffic vehicles, etc. I know you tried removing traffic, but I'm wondering if playing over 60 FPS is generating some sort of "detected impact" with the road or just a general glitch that's causing it. If you're playing over 60 FPS, trying capping it with your graphics card's driver. If you aren't, I don't know what else to say, sorry!
I used to play with an uncapped framerate and experienced all sorts of weird issues, including the one you're describing, it used to drive me nuts. Now that I capped it to 60 FPS, I haven't noticed these issues anymore.
Let me know if that ends up helping out!
Edited by Wise Omelette
Oh, okay. It might not be that then... I suppose you could still try limiting the framerate with your graphics driver software in case the game is running at a higher FPS than the monitor (I think that's technically possible, some people do it for some competitive games for a very slight advantage) so maybe just to be safe try limiting it to like 58 FPS and try that? If that doesn't work, sorry man 😞
I solved the problem, altough not the way you'd expect: I found and downloaded the original TDU - not Gold edition. So far in the not Gold edition 11 car delieveries, 10 perfect. Only one is still bugged - an olf Corvette (Stingray, I think), probably from the 50's. This car loses money as it goes.
And with the not Gold edition I also solved the other problem I didn't mention - manual shifting works, most of the time. Now I can decelerate a lot later than I had to with automatic transmission. The shadows are a little too dark
even with increased brightness but that's a small price to pay in order to have the other two things working. Also, the game won't close upon exit and I gotta kill its process, but I can live with that too.
1 hour ago, Wise Omelette said:
Oh wow, okay! Hey I can actually solve the too-dark shadows thing for you, I personally created a mod for that!
Here's the link if you want to try it, I'm pretty proud of making it 😄 https://turboduck.net/files/file/777-tdu1-simple-contrast-reductionbalancing-not-hdr-compatible/
That's nice but it could use the same values for morning, evening and what's considered "night" in this game.
I don't really get what you're saying... the only thing my mod does is create a consistent lowered-contrast across all default weather patterns. It doesn't alter anything about the order weather and time occurs in the game, everything else was left stock.
Afternoon - good contrast. The rest of the day (morning, evening, even the sort-of-night) - still too dark like with the original weather.
Posted (edited)
Gotcha okay I get it now. That seems odd, the mod applies the exact same contrast values to all times/weathers, as well as balancing out color and keeping saturation constant... so it really shouldn't do what you described. I tested it thoroughly before posting it, when I run the files I uploaded, every weather pattern has heavily-reduced contrast, like demonstrated in the photos. I don't know if you manually edited the values yourself, or just installed the file raw as I uploaded it, but to the best of my knowledge and experience it runs correctly and mellows out the contrast (without overdoing it and making things look flat, that would be weird) when installed as intended.
If you want to edit the values even more yourself, open the weather.ini file and just change CONTRAST = 1.12500 in all 20 weather patterns to some lesser value, just play around with it and enter what feels right for you!
If changing that contrast value isn't enough for you, you can also try changing BALANCE = 0.06310 0.06310 0.06310. I gotta admit, it's been awhile since I made the mod or played around with weather.ini, I'm a bit rusty on what this value did, I think it has to do with the balance of RGB color values, so it may or not help. The other two values my mod changes won't help your problem, CARGLOBALFACTOR just controls the overall reflectiveness/shininess of cars-only, and DESATURATION definitely shouldn't be touched, it just keeps everything from looking dull and gray.
Oh and here's a really REALLY cool tip for very quickly checking how all the different weather patterns look in your game:
In the same folder that weather.ini is in, find WeatherDesc.ini. Open it, and right at the top you'll see:
//Default time scale : 50
Change 50 to 5000, save the file, and run the game. As soon as you leave your house, you'll see all the in-game weather patterns and times-of-day very quickly cycling (not too fast that you can't see them though, but it only takes a few solid moments to get through all of them). Be wary the game might crash after a bit when set to that setting, but it's a great tool for quickly testing how all weather patterns look!
Be sure to change that value back to "50" when you're done testing.
[EDIT: Okay again it's been awhile since I messed with this stuff, it might actually be:
[WEATHERDESC]
Name        =    "FREERIDE"
TimeScale   =   10
the number 10 might be what you need to edit to 5000. I'm sorry, it's been months since I messed with this stuff, if the first thing I said doesn't change anything, try changing TimeScale   =   10 to TimeScale   =   5000
On top of all that, either of those values might have different defaults in your game, I can't remember if I permanently changed one for myself to change the flow of time.
sorry! Either way, change all values back to original once done testing]
I really hope that helps, sorry it wasn't to your taste the first time around!
