G25 Problem
Immelmann
Adjust your "Force Feedback Device Settings" if you prefer your wheel to be really tight at all times adjust the following three settings to max (sliders)...
* Overall Effects Strength
* Spring Effects Strength
* Damper Effects Strength
it is just then a case of adjusting those slider to get your personal prefered feel !!!
you can also ingame settings menu adjust the "Steering Sensitivity" levels to make the wheel less responsive, etc...
