Hey.
I have searched for threads, but nothing relevent came up, however if I have missed something, please tell me.
Right, whenever I go online to cruise with someone, I can connect to the one person fine (depending on the person, I can only connect to a limited amount of people), however I can only connect to one person properly in each server. So, if I connected to a 8 person server, I can only connect to one person in that server properly.
For example, if I wanted to cruise with 2 other people, I may be able to connect to both of them fine seperately, but if I try to cruise with both at the same time, only one will be connected properly with me, the other will be -//-.
This makes it impossible to have a proper large cruise, any help is appriciated thanks. :)
Btw, this is only on PC, my 360 TDU was fine.
There has been a few threads about this, like http://forum.turboduck.net/showthread.php?t=17655 ;)
I think you have the same problem I had when I started playing TDU and that is that something is playing up with your router. When we changed it things became a lot better.
Ah :fp: I didn't notice that, maybe I searched wrong.
Anyways, we only have 1 router, the one we use now, so I'll have to look for another one somewhere or try something else.
Hooooooomehub? You sometimes have to set certain parameters for it to allow, even if UPnP is enabled. It's dumb like that.
Yup. And ah, that doesn't suprise me. :p
Go to http://bthomehub.home in your browser or if that fails try 192.168.1.254 (because using a .1 address is just too simple, obviously...) and sign in. (if you need a user name it is likely to be admin it may also ask you to choose a password if it's the first time you've signed in.)
Head over to advanced and iirc there are preset drop downs for Xbox, PC gaming, VoIP etc under one of the sub menus. I know that's pretty vague but I don't even have the Home Hub! The interface is pretty straight forward and if in doubt about something simply leave it alone.
