Need Help.....with making patches
Guest April Swift
Guest April Swift
I finally mod the car suspension height that i lilke on a car with the combination of rims i love as well as body swapping.
How do i make a patch so i dont have to mess with this every time i reinstall TDU?
I would like to make a patch that will auto modify the database RIM size, put the rim in the right folder for the right car, put the body of the cars i love into the right vehicule folder along with the sound mod.
Could someone teach me how to do this please?
I am trying to make it update resource file with specific car performance data how do i enter say for example a RUF physics into the patch editor resource value paremetre?
Guest April Swift
Thank you djey i am trying to export the rim size of one car :) to your patch maker. I just dont know how to enter those datas in the patch
Here is the data of the rim for ferrari rst i have decrypted:
1243811857;57465512;61976512;5487562;225;35;19;285;35;19;2000;6;57465512;550758512;550758512;0;
I am trying to use your patch editor to add these :)
I dont think tdupe has export instruction for rims :)
ok great,
so you should add an updateDatabase instruction with following parameters:
  • resourceFileName = Rims
  • resourceValues=<the first number in your values above>|<your values above>
IMPORTANT thing for values, do not use ; (semicolon) to separate. Use TAB separator to make it compatible. You can use insert TAB feature in TDUMT's patch editor (value box).
you can also use a 2CVSUPERGT's mod pch for reference. ;)
Please make a database backup before running the patch...
Guest April Swift
Wow it did work i looked at the install output generated and found out why it didnt work before... now it's working fully thanks so much.
