TDU Platinum no force feedback for Thrustmaster TX wheel
Hello, I got TDU1 working nicely on Win11 - did several races, only a couple nuisances:
  1. Force feedback does not work at all with Thrustmaster steering wheel.
    1. I tried installing G27 fix - no difference.
    2. At first I had difficulty setting up steering axis, but right now everything is mapped and working fine (after adjusting all sensitivities to the max)
    3. Quite sure the game does not recognize the steering wheel model, but don't remember if it should?
  2. No Radio. Does not work. and there is no music in the game at any point. (I can live with this)
  3. Game crashes if I plug in my USB handbrake - driver-less game controller device. (I can live without it as well)
  • Thrustmaster H-shifter does work nicely. Currently as a standalone USB device, but connecting it through the wheel base did not help with USB Handbrake crash.
I installed game from my licensed CD copy purchased around 2008 - I used to play this game A LOT back utill TDU2 came out. But did not have steering wheel back then.
Any advice appreciated.
  • 3 months later...
i have t300 rs gt and win 11. i installed the game and project paradise or platinum mod and had ffb but i had no multiplayer functions, so i tried to reinstall the game and now i have online functions but no ffb. 😞 now i can't bind steering wheel, only handbrake, weird.
Thank you for suggestions - I now tested some more combinations - updated drivers, firmware, tried to connect gear shifter through the steering wheel (which is actually not supported - it can only be used as USB device on PC), I noticed that for some reason force feedback was set to 0% in the driver settings.
Everything works now - FFB works as expected now - my bad. TDU1 Platinum works great!
