hee,
i have some problems with tdu
first i have a problem with going online. i have an original tdu cd but my brother use the cd key and i was wondering. is it possible for me to go online with the same cd key if he isn't playing the game? i already tried but he keep saying that i must check my network thing or some:S
and second i have downloaded a carpack from internet and if i go play on my account and i go out of my house, tdu doesnt work anyone and get stuck:S
hope you can help me:)
What do you mean stuck? Freezing on 'Saving, please wait' ?? Common problem, easily solved if it is.
http://forums.eu.atari.com/showthread.php?t=69750&highlight=radial
And about the Key. You can use the same key, but not at the same time. However this does cause problems later on. I speak from first hand experience (however I wasn't doing it intentionally. *looks at Sensei*. Also, it's illegal for another reason ...
Alternate Solution, which I'm posting in every one of these theads Lol.
HOUSE SAVE FREEZE.
1. Go in game, let it load, don't click "Continue Game" Instead go to options, then Video Settings and put it on low deatil, no AA, no HDR etc. Resolution can stay as it is. Then close the game.
2. Open TDU again, this time do click "Continue Game" Browse through your garage, look at your news etc in your house for about 1 min. Then close the game again without leaving your house.
3. Finally go back in game and play as normal, you should now be able to leave your house :)
well the problem is:p i don;'t have any houses i just started cause i played offline with a savegame from internet:P i begin at rent a car and stuff:P
YEEEEEEEEEEEEEEEEEEEEEEE i solved both problems and i can play online now:D:D:D woehooeeee yeeaaa now i need some cash and a car(H) w00h000
im happy:D
If you and your friend are still using the same CD-Key, then it will cause some problems later on. When both of you try to log on, it'll kick one of you, as it recognises that you both are using the same Key. Also, when you finally decided you both want to be on together and one of you changes key ... your previous profiles will not work, as they're attached to your Key.
This is coming from first hand experience, even though I wasn't the one who had to restart their profile xD
well my brother doesnt play online so i don;t have to worry about it cause he always play offline;) but is it true that the servers aren't always availeble?
