I remember seeing this a while ago and I think you get it whenever any key is pressed for a long time. Or maybe it is just the C key. But as far as us players are aware it maybe alerting you you're holding the key down or maybe it was a feature left out in TDU1.
In cockpit view right?
And it says x5 then x1 and over and over right?
It changed how fast the camera turns, simulating how your head moves especially when cornering. On x5 your "head" turns quicker and on x1 your "head" turns at a more gradual pace
This is the speed of when you look around the car, x1 is slow speed and x5 is fast (or it could be the other way around). You should notice it when you look out the side window.
Thinks thats what this does
When in the cockpit it changes how quickly your driver looks around; ie 1x = extremely casual slow moving chilled out avatar being able to look all around the car, 5x = instant left and right with no room for up down or all around. Outside the car it will also lock the camera to that position so if you want some of that driving while looking at the side of your car action then you can have it.
Welcome to Salami Hospital!
