This is very wired. When I have my foot down on my accelerator, and apply the clutch to raise rpm higher, it is not steady, and it rattles up and down not giving me a smooth boost, but rather very agressive and doesnt feel right at all! I checked the Clutch components by the hole surrounding all the pedals, and all i could find was just like: hairs, dust. Is this why? Or is it just broken?
Well, the compressed air is powerfull enough to get into all the little gaps and blow out all the dust and anything else that could be blocking something. It'll just give it a good little clean out.
HeLeX, Sponge means "Canned Air". It's just a can of compressed air for blowing the gunk out of computers. You can get it at any computer supply shop.
Caution: Be sure not to turn canned air upside down when dusting out your equipment. It will blow out liquid air which will freeze anything it hits. If it hits circuit boards they WILL crack and be damaged; if it hits skin you WILL get frost bite. Alway hold the can straight up (once it starts getting empty you can tilt the can to about 30~45 degrees if needed).
whoa! That is too risky just to solve a small problem. I might as well get cotton buds and extract that crap our myself. Thanks anyway, but that, I am not doing.
Its not that risky... Just dont put it upside down like Degenatron said lol. Its a sure way to get everything out, if you use cotton buds then you might just push the dirt in further and clog it up even more...
