did u download tdu from torront if so it will not work
Since he said he got it from the Atari website, this isn't very helpful is it?
As for your question, you could delete the radial.cdb file from your application data, that tends to be the cause of a lot of errors.
If that doesn't work then AFAIK the no disc error tends to be to do with if you've had TDU on your system before. Maybe try deleting every file from your hard drive and redownloading and reinstalling. I'll write you out a list to make that clearer:
Uninstall TDU (Backup your profile somewhere else)
Delete any files left over (including your profile from my documents)
Restart your PC.
Download TDU from testdriveunlimited.com
Install TDU.
Restart PC.
Play TDU to check it works and insert your serial.
Put your profile back in your documents and check it works in game.
Download megapack from official source.
Install megapack.
Restart PC.
Launch TDU and insert megapack serial.
Hopefully that should solve the problem, good luck.
I have the same problem, it is very difficult to my TDU start, like 1 in 50 tries it starts, maybe that radial.cdb solve my problem but I can't find it.
someone please help me, it is making me get annoyed.
