I´ve put in my Ruf the RGT rims and look good but is a problem Take a look:
Is there any solution for this (changing something of the rims with TDUPE or TDU Modding Tools)?? Or to correct that bug i need the Zmodeler??
Sorry, my English isn´t very good. :o
its not much work.
1. open zmodeler and load the rims
2. click on move, with Move Pivot Only
3. select top or front\back view also be sure you select only X axis
4. click on the rim and drag the pivot a little bit to the center (you will have to experiment)
5. export, replace, enjoy :)
  terzer said:
its not much work.
OK, I will do right now. Thanks!
