Question
I seen your post on the SMF forum.
I have two forums that need help! I also want to learn to do more things on my own and not just have stuff done for me too.
But one at a time.
  1. The signature box in the edit profile is white and so i the text so people can't set up signatures very well and I have DarkModern Theme installed.
  2. One I have staff page mod installed but no link showed up in the link bar but the page is there and working properly.
  3. I would like the Blog mod installed. Installs but once in stalled it does not function.
  4. I would like the country flag mod installed.
  5. Also would like the Shop Mod installed.
Thanks for your time.
RoCKeT~
  • 0
eh... cough.. would you mind change your avatar... cough...
1, i don't quite get what you're saying, can you explain it little bit more with screenshots
2, to add an button, go to your subs.php file, find
//all the buttons
under that you will see whole bunch buttons lists
simply insert one to where you would like it to appear in follow format
'name of the button' => array(
'title' => 'name of the button',
'href' => 'your url',
'show' => true,
'sub_buttons' => array(
3,4,5 did you get any error during the install processes? if so post them
  • 0
You dont like the only thing that will be left after the end the of world~ lol Beats empty the default I thought and it's the same I use on SMF~
OK Lets start with No. 1.
  • 0
actually i haven't seen one of them in years, and yes, i don't like them (seeing them = that place is dirty
back to the question:
for that i need to know the style name of the text
can you pm and give me the url of your site and a test account so i can check the source code
  • 0
sry i missed a space
search for this
// All the buttons we can possible want
any account that has permission to edit signature is fine
tho it would be better to just gimme your log in for if you want me to manually do mod installs for you etc (i will need ftp log in as well
  • 0
search for this
I am getting nothing with buttons on .....Sources/Subs.php
  • 0
i have installed blog and shop mods for you
they gave errors for couple search operations bcuz the original codes were changed, i manually changed them for you
as for the flag mod, i don't see this mod in your package page
  • 0
Only thing about the sig box is changes the post message type too. How could I change the profile signature box background to another color and keep the text white. Although that is not a major issue.
  • 0
I wonder if the flag mod was taken all the way back out maybe.....I will see shortly.
Now the blog, when I click on the blog link I get
An Error Has Occurred!
This Module is not active
  • 0
go to your index.css
find
#map_canvas input, textarea {
background-color: #FFFFFF;
change #FFFFFF to the hex color code you want, you can also use predefine colors such as blue, red, green
  • 0
that's something has to do with the mod itself, ask the mod author for support
  • 0
Yeah what I really want to do is change the background color of the sigbox to be dark and the text white....how would I do that....sorry reading about this blog thing.
  • 0
find
to change the background color
  • 0
OK that will be great....I will try that shortly!
One more thing in css where would I change the default post size. Its fine when your typing out the post but after it goes live the text imo is too small.....
  • 0
  On 4/20/2012 at 5:29 AM, Eudemon said:
to change the default font size, in index.css
find
.post {
clear: right;
margin-top: 0.5em;
change to
.post {
clear: right;
font-size: 16px;
margin-top: 0.5em;
Wow thanks! I will do that shortly! My mind is fried this is hard work for me!
Answer this question...
