That looks like you're trying to put that BMW onto a MuscleCar slot.
In most cases, the musclecar slots try to dictate smaller rim sizes.
You can try changing the "Default Rim" option in TDUPE to something like the AC427 or one of the other musclecar options, if that doesn't work, you need to use a different car slot.
Thanks, Kurgan, you helped me a lot but I still couldnt get the rims in full size (they were bigger but not full size).
Anyway, the mod work ok with original rims which I tried to replace because I dont like them...
One more time thanks!
Keep trying with different rim options in TDUPE, there might be some even bigger than AC427 but I've never needed to use them.
I usually stick with the Maserati Cambicorsa for "just a little bit bigger", and then the Ferrari F-40 for "about 2 inches bigger".
There's no really set way to judge what you're going to get, it's trial and error really.
