Sign in to follow this
Psyhoman
G27 Calibration problem
I have problems with my G27. At the "Controls" menu when I set up my wheel, if I press the gas or brake pedal to the max it says "Press only one key or axis at a time". So this brings up the problem that even if I slightly touch the pedal it gives more power. At the middle point of the pedal I receive Max Power in TDU :confused:. Any help will be nice. Thanks in advance!
Share this post
Link to post
I had this problem when I first played TDU2 final (not an issue in the beta). Solution was to close/terminate the Logitech Profiler before launching TDU2. You could then map the controls.
Eventually the problem sorted itself out, so I can use the profiler to force a bit of extra centering spring to compensate for the lack of FF in the game.
Share this post
Link to post
Announcements
