Savegame Problem
Arnaud Acking
Can you check the properties of the 'Eden games' folder in my documents, the box at read-only should be unchecked. Also make sure that your tdu2 launches as admin, for that you should just run universal launcher as admin. Also make daily/weekly backups of your savegames, you never know when a problem appears.
I don't know if you can use the same savegame if you've changed CD-key. In TDU1 the savegames were linked to the CD-key they were created with, feels strange that they would take a step backwards in that perspective. Perhaps this means you can use the old save but not save anything new to it. I don't know.
  • 6 years later...
