Accelaration & Car help
vaism
I want to drive my car with a smooth control of it, do you get what i mean? if you realize the turning & and the brake is a little to strong, i want to control the car to be more realistic, how do i do that? Secondly I just bought a R34 Skyline from the Nissan showroom and when i wanna take it for a spin i'm able to start the engine, the gear is set to N able to accelarate but unable to shift gear to 1 basically i'm unable to make the car move... I hope you understand me.
Much Thanks
i have an xbox 360 design gamepad, powerwave brand, and the triggers dont do anything like you want e.g. restricting the revs to whatever you want. as for changing gears, go into options - controls - driving (something like that) - then look for gear up and gear down. set it to a button you will remember, and then you will be able to change your gears. to get that rev limiting, you will need a wheel with pedals to get that effect. the controller i have just doesnt do it UNLESS i change the throttle to a stick. i picked mine up for 20 australian dollars on sale. normally 30.
i used to have the same one it had the carbon look on it too.. but i upgraded to an xbox 360 wired controller
