Need Help!!!!!!!!
CarFreak
Guest turbo lag
What other mods have you installed during the time?
If none of the suggestions work, just uninstall both Tool's mods and the game will be fine. Then you can manually install them.
I did the manual install
Take the physics off, remember you can't use them in online mode, but if you play offline, then you should be fine so..
I dont play online
