Yes, I know Urban has done this before, but as sound is something that can go completely different, I tried to do this by myself. I didn't stole anything from him, just did everything alone, as always.
[TUBE]<object width="640" height="385"><param name="movie" value="
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>[/TUBE]
Filefront
Mediafire
Rapidshare
PS. Recommended ignition time with roar - 2.2 seconds.
Without roar - 1.05 seconds.
Yes he removed the backfire or didn't use the NFS Shift sample and it is a little more high pitched.
I would have a small objection, though: the transition between idle and onlow needs a small fix. Hope you agree with me and take it as a constructive comment.
Great mod, excepting that.:cheeky:
Transition between idle and onlow is a bit compromise, because I had a problem: the transition was bad or the idle sound was completely unrealistic and fake. Although it doesn't sound that bad ingame, cause in the video some idiot in Audi S6 spoilt it. And I used all samples from Shift, but I had to shorten some of them, cause otherwise it would exceed the 750 KB limit and it would end up in huge silence :rolleyes:
And I like doing mods for myself, just as I want them to be.
good to see you back man :)
great ignition, very good, but why have it if it doesn't match the mod? :rolleyes:
the mod itself though, is great also i might add ;)
Yes, I know the ignition does not fit with the idle. You can always shorten it in TDU PE, so this roar will be cut and it will be ok. But I just adore this roar, and I don't care if it doesn't fit.
Wszystko super, ale mam jedną uwagę. Mianowicie to nie podoba mi się przejście na niskie obroty przy uruchamianiu (chodzi o to, że jest bardzo głośno, a za chwile już bardzo cicho). Moim zdaniem powinno być to trochę łagodniejsze przejście.
Pozdrawiam
Pozdrawiam
He says that volume change between starter and idle is too big.
Solution: ignition time 1.05 seconds.
Hi, I am new to this forum, so please excuse me if I do not behave like the rest of the community. Anyways, this sound will not work on my Gallardo. It's as if there are no car noises. Any way to fix this?
  • 6 months later...
Guest Aussie.Guy
holly JESUS I love this sound thank you
but please dont upload to scam sites like rapidshare
