Hi,
I have problems using the Logitech MOMO force steering wheel. When the steering wheel turns left, the profiler puts it as axis- moved. And, the accelerator ALSO is put as axis- moved. (Same for steer right and brake pedal, except it's axis+ moved.) So, TDU regards both of them as the same command. Now I cant Steer AND accelerate together. How do I fix this? Help much appreciated.
P.S. If this is the wrong place to be posting this, please move it to the correct one. Thanks!
They should be two separate axis' (i.e. Axis X for steering and Axis Y (sometimes Z or a slider) for the pedals.
Easiest thing to try first is to unplug the wheel, uninstall your drivers (profiler), restart Windows, download the latest software drivers, install them, plug in the wheel (only when the software tells you to) and try recallibrating it from there.
Then go back into the game and setup your controls again.
