How to remove gear shifting sound?
HeLeX
I have recently downloaded a new sound for my car, but I noticed when I'm in the interior view and I change gears with my G25 Shifter, it not only makes one sound but two sounds. One sound occurs when I go from 3 to N, and then from N to 4. Is there any way to completely remove the gear shifting sound of a car, especially a Manual?
Not without removing it from other cars using the same wav.
But if you want to remove the gear shift sound(s) across the board, you can.
The sounds are located in "..Euro\Bnk\Sound\Vehicules\common.bnk"
Use the TDU Modding Tools to extract the wavs from this file.
Then use a wave editor to edit the shift sounds.
You can either manipulate them to make them sound like you want,
or simply change them to 0.1 seconds of silence, if you prefer no shift sound at all.
When you're done save the file, meaning "save" not "save as" this is the easiest way to preserve the format (ACM).
Finally use the TDU Modding Tools to inject these wav files into "common.bnk" and replace the default sounds (choose "modify size" method).
And make a backup of "common.bnk" before you start.
