As you probably know, Illusion Island Paradise mod have a problem with the road texture. He has spend day's to find the solution. I tried to help him but I failed also...
I am pretty sure what the problem is. I think its the mipmap count.
The file cachecrossroad_detail.2DB has 6 mipmaps and is dxt1-like. If you make it a dds file it has 5 mipmaps (witch is o.k.).
Now the part where all goes wrong: If you use the DXTBmp programm to open the file and save the file without modding, than you get 7 mipmaps. 2 to much! After making the file 2db its 8 mipmaps. The DXTBmp program should save just the 5 mipmaps. The result is black road textures in the distance.
So I tried another approach. I tried to not use the DXTBmp programm. Instead I open the dds file directly with photoshop (CS5 with nvidia dds plugin). I open the file without mipmaps and than try to save it. I saved the file with 5 mipmaps and no other adjustments as dxt-1 argb file (also tried rgb). After that I conferted it back to the 2db file and its has 6 mipmaps. Thats just great! I thought... The new texture isn't black in the distance witch confirms my idea of the mipmaps. Only problem is that the new texture is blue with green in the distance :cry:. From close it looks ok. So i am sure that the file saving is not done right!
My question: Is there a way to make the DXTBmp program use the 5 mipmaps instead of 7? If not, what is the correct saving method in photoshop?
There are quite a few persons who should know the answer, becouse their textures has the right amount of mipmaps. Please Help!
I and probably Illusion will be very happy with the solution!
