yoo guys. I unpack the game. and i launch the game with tdu2 universal launcher and then the game starts. And then says press start & when i press start game crashes? :( Can anyone help me?
Already answered in another topic
http://forum.tdu-central.com/threads/27337-Can-t-find-BNK-files-(Steam)?p=460750#post460750
You used the normal launcher?
You must use the Universal Launcher is not the same game crashes.....
Sole reason for the game crash is to use the launcher normal game or a poorly installed Mod .....
Or even as Panikos said, the problem Unpacker .....
Except that there may be a way to fix this problem, you have backed up files as was put in the tutorial? So from now you want to do the same process again, will have to reinstall the game because it has no way do Unpacker 2 times in the same plant.
What I advise you: If you reinstall the game, copy the game folder (Any folder of the game) to a different partition of the HD and make the process Unpack it, and if it does not just only delete this copy of the folder. ...
If you remember to run the Launcher NOT RUN common bug game is not going the same way ....
