How to use camera hack? I opened hack room before the game and then I open the game, but pushing the buttons chosen by room hack does not move the view, but it only opens the radio. I have to touch any of the settings? Does anyone know how to fix this? thanks
On DlC 2 you need camera hack 1.1
@ PASSI286 Actually 1.2. is the better option.. It was only 1.3 that didnt work with dlc2. so anything before that works and you might as well go for the most recent working one.. which is 1.2. But that aside you didnt actually give an answer to his direct problem. Don't just say " USE THIS" you should explain why or at least give a simple reason why he is doing it wrong...
@ ferrarithebest.. You might need to change some of the controls in your game if they conflict with controls used by cam hack. But as both Passi and myself have said Cam hack V1.3 will NOT work with the game anymore... you will need V1.1 or 1.2 ( 1.2 is the better choice it has more features)
ALSO.... you also might want to use better translation software. because your english translation is pretty hard to try and understand :)
Hope that helps you..
Nobby
