I am new in two things: playing racing games with a gamepad and TDU itself. Well, I played some time ago some racing game, and I liked it.
Now I tried to use Dualshock 4 on PC (Win 10) in TDU via DS4Windows and I faced some problems with sticks: game always asks to "Press only one key or axis at a time" whenever I try to assign sticks to turning left and right. Every other button works good although that message pops really often and I succeeded in assigning only after dozen of presses.
Is there a simpler way to use DS4 in TDU?
Thank you
Posted (edited)
Maybe you can try recalibrating the controller, wrong calibration will make the game think some axis are still in use.
Otherwise, if it is possible, disable rogue analog axis in DS4 settings (I can't quite remember, used DS3 ages ago).
Edited by Djey
Expand
It works perfectly outside the game. Nonetheless I've recalibrated the device. No use.
And I didn't figure what to do with the second option.
I use the DS4 fine. I forget how I set it up exactly but I remember setting the triggers as right stick x & y, because the normal L2/R2 buttons are recognized as z-axis (which means both triggers are bound to a single axis).
