everytime i try to go online on tdu it says "can't connect to the test drive serever". i installed the megapack and put the serial key in thats when it started to happen. Before i installed the megapack i was able to go online but now i cnt. i reinstalled tdu but it has the same problem. is tehre anyway of fixing this. plzzzz help:(:(:(
Same problem,
I ahd the game years but recentl installed a friends mega pack but now cantconnect at all, tried lots of stuff, have they blocked by IP or something or do i need to remove programme date?
Thanks
Ministry
samiul95 try deleting radial.cdb (i cant remember where to find it)
Ministry you need your own megapack its only £20 or there abouts
the megapack is a waste of money, if i payed 10 pounds for the actuall games why would i pay 20 for a megapack
Samiul95
I maybe know the problem here..I wrote in the TDU Serial key instead of the Megapack serial into the Megapack Activate add-on.
You need to write in the Megapack serial you got in the E-mail from the company you bought it from.
So I maybe think this will help.. I wanne hear if it goes good ;)
Beem3r
Using someone elses registered Megapack that is tied to their serial when they login will not work and will result in you (and your friend) being listed. Get your own pack, put in your own Multiplayer Key then activate and job done.
