Posted (edited)
21 hours ago, MagicV8 said:
I reuploaded the mod, same link like above.
Dude I couldn't thank you enough. This is the best gps mod I found and am so grateful for you!! Thanks so very much.
Slight issue, this completely destroys the full map, default key "M". The mod makes it hard to see things unfortunately whereas the vanilla map is fine. The minimap is the opposite, vanilla is impossible for me to see the route whereas this mod is perfect. I can't have the vanilla full map and this mod's minimap at the same time due to how the game's map system works can I?
My issue, and why I needed this mod specifically, is that I can't see the route on the minimap because it is so very thin and difficult to see with all the terrain, I also can't zoom in enough. As stated, vanilla full map is fine, vanilla minimap is problematic.
Do you happen to know of a mod that either changes the minimap's route color, or maybe thickness, or something that would allow the minimap to zoom in some more? I only recently started playing the superior perfect PC version, was always used to the PS2 version where the minimap is big and easily readable.
I apologize for wasting your time reuploading the mod. I didn't know it affected the big full map too. I should've known though since I assume the minimap takes it's data from the full map in real time and does not use it's own exclusive set of separate map tiles.
Edited by joe00173
On 8/16/2021 at 11:55 AM, MagicV8 said:
Sorry, but I cannot help with this.
Don't worry about it. I seriously appreciate you uploading it anyways. I am definitely fine with the full map issue, it's not a deal breaker. 🙂
  • 11 months later...
