Ferrari F40 LM chassis number 88522[v1.0a]
Vehicle replaced: wichever floats your boat
Online: no
Creator: Ten.
Tested with G27. Very realistic, imo. For the full experience, MUST be used with Doctor G.'s BETA F40 LM sound and Reventons F40 LM. I put mine on the Lexus GS450h, works like a charm. If you DARE it can be tuned at Forza Tuning(800hp+).
Some info about the thing.
The sixth LM built, chassis '88522' was delivered new via POZZI (Ferrari France) to none other than the famous French cartoonist Uderzo, creator of the celebrated Asterix cartoon strip. Uderzo, a keen and long-standing Ferrari collector, used the car exclusively for private test days, and during one of these damaged the front bonnet. The car was returned to the factory for a replacement and the opportunity was taken at the same time to convert it to run on unleaded fuel, an important advantage for future collectors.
88522
First owner: Uderzo
Crash on track in rear by Uderzo - repaired by Pozzi in Lyon
David Morrison via Dealer
97/2 - Fandel, G 850,000 DM
98/5 - $455,000
98/6 - $465,000
98/dec/19 - S - Auction Switzerland sold for 619,500
Germany
Country of origin Italy
Chassis number 88522
Numbers built 19 (#6 of 19)
Produced from 1989 - 1994
Engine
Configuration F120B 90º V 8
Location Mid, longitudinally mounted
Construction light alloy block and head
Displacement 2.936 liter / 179.2 cu in
Bore / Stroke 82.0 mm (3.2 in) / 69.5 mm (2.7 in)
Compression 8.0:1
Valvetrain 4 valves / cylinder, DOHC
Fuel feed Weber-Marelli Fuel injection
Aspiration Two IHI Turbos with two Behr intercoolers
Drivetrain
Chassis/body kevlar body on steel spaceframe, integrated with composite materials
Suspension (fr/r) unequal A arms, coaxial springs, Koni hydraulic shock absorbers, anti roll bar
Steering rack-and-pinion
Brakes vented discs, all-round
Gearbox 5 speed Manual
Drive Rear wheel drive
Dimensions
Weight 1050 kilo / 2314.9 lbs
Length / Width / Height 4535 mm (178.5 in) / 1980 mm (78 in) / 1150 mm (45.3 in)
Wheelbase / Track (fr/r) 2450 mm (96.5 in) / 1580 mm (62.2 in) / 1570 mm (61.8 in)
Performance figures
Power 720 bhp / 537 KW @ 7500 rpm
Torque 706 Nm / 521 ft lbs
BHP/Liter 245 bhp / liter
Power to weight 0.69 bhp / kg
Top Speed 367 km/h / 228 mph
0-60 mph 3.1 s
Note, the grip level has been edited since the screenshot, it should do 3.1's without having to get a uber perfect launch now. (i did 3.05 once with the old griplevel)
http://img688.imageshack.us/img688/6132/testdriveunlimited20110.png
!!Please make sure to backup your original files before installing this mod and read the included README file if there is one!!
http://www.filefront.com/17825513/FERRARI F40 LM chassis 88522.tdupk
Requires Djey's Magicmap
Mod History
v1.0a - Released
Terms of use:
- The models, skins and other files are for private use only
- Commercial use of this modification is strictly prohibited
- All Registered Trademarks and Copyrights are property of their respective owners
  • 3 months later...
Have anyone had problems? Another chassis number and want to know about any kinks in the handling of this one, etc before release.
