Cambermod-How to use?
Audix3
Hi guys,
as this is the support section, I hope somebody is able to explain how to use the cambermod to me
I cant get it to work
I was able to set the camber in the following procedure.
- Start the cambermod and the TDU2. It does not matter the order.
- Go out the house.
- Switch to the cambermod.exe in the ALT + TAB,
- Do the desired setting, and then press the SAVE at the end,
- Switch to the TDU2 screen with ALT + TAB.
When return to the garage, it seems be reset.
I wish you good luck.;)
  • 1 year later...
